2 items, only 1 shown
  • just4fun
    • Jun 2010
    • 32
    Hello all,
    for one of my server I have defined the following items:
    vfs.fs.size[/export,used] and vfs.fs.size[/export/data,used]
    when running zabbix_get both work, but in web (at "latest data")
    I only see the first one (/export)
    Any idea what's wrong? Is it a bug?
    Christian
  • richlv
    • Oct 2005
    • 3112
    the second one has not received any data in the server yet
    • just4fun
      • Jun 2010
      • 32
      probably possible, but why? both are active, nothing in the log....
      which level should I set for debugging to get info about which items have been
      checked or not?
      • richlv
        • Oct 2005
        • 3112
        if you go to item configuration, do you see any error messages next to the problematic item ?
        • just4fun
          • Jun 2010
          • 32
          no, there aren't any. both items are active.
          probably it has to do how items have been created. first item (the one for
          filesystem "/export") has been inherited by a template. the second one (the
          one for "/export/data") has been cloned from the first (and is now a local item
          for this host only).
          I experienced this also for another host which has 2 similar additional items
          to "/export" (it has also "/export/data" and "/export/home"). i created the
          additional items the following way:
          /export/data is a clone of /export ----> and not shown in "Latest Data"
          /export/home is a clone of /export/data ---> and... heureka... it's shown in
          Latest Data!!
          ok, so i know a workaround to have all my filesytems shown.... but any idea
          why it is so? did i hit a bug?
          christian
          • richlv
            • Oct 2005
            • 3112
            the way you created the item should have no impact on data availability.
            what are item intervals and for how long did you wait for the data to appear ? have you changed item types after creating them ?
            • Wonderer
              • May 2010
              • 53
              Latest Data!!
              christian
              Can you try to run following command from the shell on the zabbix host:
              zabbix_get -s<IP_Address of server> -kvfs.fs.size[/export,used]
              and
              zabbix_get -s<IP_Address of server> -kvfs.fs.size[/export/data,used]
              Do you see output for both commands?
              • richlv
                • Oct 2005
                • 3112
                note that the original poster in the first post said "when running zabbix_get both work" - i assumed that's true
                • just4fun
                  • Jun 2010
                  • 32
                  yes, you're right, zabbix_get works on both
                  I now removed the not templated item and created a new clone from the
                  template an now it works... hmmm... funny
                  seems that there are some bugs in the UI... I also found that sometimes items
                  get activated for one server when modifying items of another server.... but as
                  already said in my first post, I'm a complete newbie to Zabbix and probably
                  doing lots of mistakes when using the UI.. but... I'm learning
                  • richlv
                    • Oct 2005
                    • 3112
                    that should never happen, obviously. can you reproduce that with the latest zabbix version ?
