Log or debug for Media Types
  • akarim
    • Aug 2008
    • 33
    Hello.
    I usually use a script sms.sh for sending critical alerts.
    Until now I was working.
    I had to change the operator for a change of residence, and now I find that the script, to modify, I work in the shell but does not work in Zabbix.
    Can not find how to locate the log of zabbix or way to control if the script is called by zabbix and it fails.
    I'm desperate.
    The script I have it as always on "/ path / zabbix / bin" (same path that zabbix_server.conf) and with the same permissions.
    I only changed the script to make a call to another php file as the new supplier only has programming in php for example.
    If I run it in console passing parameters 1, 2 and 3 works perfectly.
    Help please.
