Zabbix-agent returning wrong value
  • dreas
    • Aug 2007
    • 89
    We ran into a very weird bug. Using Zabbix Agent v1.4.6 and Zabbix server 1.8.2.
    The agent is returning the correct response (0):
    host:~$ zabbix_agent -c /etc/zabbix/zabbix_agentd.conf -t mysql.replication.status
    mysql.replication.status                      [t|0]
    host:~$
    The agent log however shows:
    mysql.replication.status:120:0
      2603:20100701:121955 Parsed [mysql.replication.status:120:0]
      2603:20100701:121955 In add_check('mysql.replication.status', 120, 0)
      2603:20100701:121955 Run remote command [/home/user/zabbix/mysql.replication.status] Result [1] [1]...
      2603:20100701:121955 For key [mysql.replication.status] received value [1]
    The server indeed received value 1, whilst it should definitely be 0. We have had this problem on different machines. Any ideas how it can be resolved? We cannot trust our monitoring if the agent results are wrongly sent of course.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Are your sure your script does not depend on some environment variables, a special shell, user, whatever? Show us the command.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • dreas
      • Aug 2007
      • 89
      #!/bin/bash
      SQLresponse=`mysql -e "show slave status \G" | grep -i "Slave_SQL_Running"| gawk '{print $2}'`
      IOresponse=`mysql  -e "show slave status \G" | grep -i "Slave_IO_Running"| gawk '{print $2}'`
      if [ "$SQLresponse" = "No" ]; then
            echo "0"
            exit
      fi
      if [ "$IOresponse" = "No" ]; then
            echo "0"
            exit
      fi
      echo "1"
      exit
      So manually running the script was indeed responding 0.
      • dreas
        • Aug 2007
        • 89
        Okay, so the user "zabbix" indeed has no MySQL permission (we should pass the password), which is why this is failing :S Apologies! Completely a mistake on our end.
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          I knew it!
          Alexei Vladishev
          My Twitter
