Problem with Simple Checks
  • RealEnder
    • Dec 2005
    Helo,
    Today I made a fresh new install of 1.1beta3.
    After doing all nessesary configurations, I added a single host(accessible via IP), then via Items tab added simple check with key "icmppingsec". The result was this message:
    Simple check [check_service[icmppingsec,10.20.0.31]] is not supported
    Infact, no simple check is able to perform, and the que is empty.
    I've used the 1.0 version some time ago and it worked fine ...
  • RealEnder
    • Dec 2005
    problem solved
    Of course, the fping utility could not be started via zabbix user...
    sorry for the SPAM
    • pdwalker
      • Dec 2005
      • 166
      - do you have fping installed?
      - is it on your path?
      - is the path to fping defined in your server configuration file?
      - is the program setuid root?
      - can the zabbix user run fping?
      It's working perfectly for me in 1.1b3 once I sorted the above issues.
      - Paul
      [edit: sorry, just noticed the problem was resolved.]
