Graphs not updating
  • Thib
    • Feb 2010
    • 25
    Graphs not updating
    Hey,
    I have some problems with my zabbix,
    I've done a dump of my database, in order to move the BIIIIG ibdata file created by zabbix.
    So, what i did,
    1°) mysqldump on zabbix database
    2°) mv ibdata1 anotherplace
    3°) mysql > remove database zabbix;
    4°) mysql > create database zabbix;
    5°) mysql > import of the dump created on the new zabbix database.
    Now, i have some troubles with graphs : last values are OK, but not graphs.
    Image hosting and photo storage for your high-res photos. Upload, organize into albums and share anywhere with ImageShack. Plans from $3.99/month.
    All i can see in my zabbix_agent log is
    6315:20100707:115456.018 Can't parse list of active checks. Can't open JSON object "NOT OK"
    6315:20100707:115656.027 Can't parse list of active checks. Can't open JSON object "NOT OK"
    6315:20100707:115856.076 Can't parse list of active checks. Can't open JSON object "NOT OK"
    6315:20100707:120056.086 Can't parse list of active checks. Can't open JSON object "NOT OK"
    6315:20100707:120256.103 Can't parse list of active checks. Can't open JSON object "NOT OK"
    so, what can i do?
  • richlv
    • Oct 2005
    • 3112
    1. you should have created the new database with utf8 charset;
    2. is zabbix server running ?
    • Thib
      • Feb 2010
      • 25
      Yes it is, i've also tried to reboot it, then can see on my map the "Zabbix Server is unrecheable", which is correct.
      Do i have to erase again my database, in order to create a new one specifying the charset ? (how do you charset a nee database when creating it in commande line?)
      • richlv
        • Oct 2005
        • 3112
        you can either delete the db and create new one according to installation instructions (http://www.zabbix.com/documentation/...#zabbix_server), or you can convert it - see portion of upgrades/dbpatches/1.8/mysql/upgrade script
        edit : oh, but your problem most likely isn't caused by that. check zabbix server logfile - any errors in there ?
        • Thib
          • Feb 2010
          • 25
          mmmh ok, i dont understand.
          i can choose my own period of view, you know, 1h, 2,, 4h, 1week, etc
          when i set it on "week", that gives me the screen i gave you. And i'm told the last value is 931GB what's wrong
          when i set in on "2h", the values are ok, the graph is OK, and my last value is correct...
          ..? o_O
          • richlv
            • Oct 2005
            • 3112
            hmm. i somehow missed it on the first run... but that's zabbix 1.6. so it's a bit... old.
            is it at least latest 1.6 version ?
            • Thib
              • Feb 2010
              • 25
              Nope it's not, it's an 1.4 version
              You can understand why i'm updating
              Anyway, thank you four your answers
              • richlv
                • Oct 2005
                • 3112
                oh. then i suppose there's not much use trying to figure out why there are some oddities
