Stuck in RHEL5
  • zabbixnewbie
    • Jul 2010
    • 28
    Stuck in RHEL5
    I already install zabbix with following command
    ./configure --enable-server --enable-agent --with-mysql=/usr/local/mysql/bin/mysql_config --with-libcurl
    I manage to start my server,agentd and mysql services.
    Anyone can tell me how to access to the Web Interface?
    I already copy all the php files to /var/www/html/zabbix but when i type "http://localhost:10050/" -> it return page cannot be display
    if type "http://localhost:10051" -> it return "OK"
    Anyone can tell me where goes wrong?
    Rgds
  • MrKen
    • Oct 2008
    • 652
    Perhaps you could try http://<IP ADDRESS>/zabbix
    or http://<IP ADDRESS>/index.php
    • zabbixnewbie
      • Jul 2010
      • 28
      Same with "Page cannot be displayed"
      Any else configuration i can check?
      • MrKen
        • Oct 2008
        • 652
        Are you sure that mysql, http, zabbix_server and agent are running?
        Anything in the zabbix_server.log or the http/error_log?
        • hipikll
          • Dec 2008
          • 12
          first check, if apache2 is running.
          then enter http://<serverIP>
          it should return "It works".
          It it wont, then check your apache.
          Then enter http://<serverIP>/zabbix
          it should return something.
          • zabbixnewbie
            • Jul 2010
            • 28
            zabbix_server.log
            2858:20100722:151942.737 Starting Zabbix Server. Zabbix 1.8.2 (revision 11211).
            2858:20100722:151942.737 **** Enabled features ****
            2858:20100722:151942.737 SNMP monitoring: NO
            2858:20100722:151942.737 IPMI monitoring: NO
            2858:20100722:151942.737 WEB monitoring: YES
            2858:20100722:151942.737 Jabber notifications: NO
            2858:20100722:151942.737 ODBC: NO
            2858:20100722:151942.737 SSH2 support: NO
            2858:20100722:151942.737 IPv6 support: NO
            2858:20100722:151942.737 **************************
            2860:20100722:151942.746 server #1 started [DB Cache]
            2861:20100722:151942.747 server #2 started [Poller. SNMP: NO]
            2862:20100722:151942.751 server #3 started [Poller. SNMP: NO]
            2865:20100722:151942.753 server #4 started [Poller. SNMP: NO]
            2867:20100722:151942.755 server #5 started [Poller. SNMP: NO]
            2869:20100722:151942.756 server #6 started [Poller. SNMP: NO]
            2871:20100722:151942.758 server #7 started [Trapper]
            2873:20100722:151942.760 server #8 started [Trapper]
            2875:20100722:151942.761 server #9 started [Trapper]
            2877:20100722:151942.763 server #10 started [Trapper]
            2879:20100722:151942.765 server #11 started [Trapper]
            2881:20100722:151942.766 server #12 started [ICMP pinger]
            2883:20100722:151942.768 server #13 started [Alerter]
            2884:20100722:151942.771 server #14 started [Housekeeper]
            2884:20100722:151942.771 Executing housekeeper
            2887:20100722:151942.777 server #15 started [Timer]
            2888:20100722:151942.778 server #16 started [Poller for unreachable hosts. SNMP: NO]
            2891:20100722:151942.780 server #17 started [HTTP Poller]
            2893:20100722:151942.784 server #18 started [Discoverer. SNMP: NO]
            2895:20100722:151942.788 server #19 started [DB Syncer]
            2897:20100722:151942.790 server #20 started [Escalator]
            2858:20100722:151942.792 server #0 started [Watchdog]
            2884:20100722:151947.939 Deleted 0 records from history and trends
            2860:20100722:161542.958 [Z3005] Query failed: [2006] MySQL server has gone away [select hostid,proxy_hostid,host,useip,ip,
            dns,port,status,useipmi,ipmi_ip,ipmi_port,ipmi_aut htype,ipmi_privilege,ipmi_username,ipmi_password,m aintenance_status,mainten
            ance_type,maintenance_from,errors_from,available,d isable_until,snmp_errors_from,snmp_available,snmp_ disable_until,ipmi_errors
            _from,ipmi_available,ipmi_disable_until from hosts where status in (0) and hostid between 000000000000000 and 099999999999999
            order by hostid]
            2860:20100722:161542.958 Database is down. Retrying in 10 seconds
            2893:20100722:161542.994 [Z3005] Query failed: [2006] MySQL server has gone away [select druleid,iprange,name,unique_dcheck
            id from drules where proxy_hostid=0 and status=0 and (nextcheck<=1279786542 or nextcheck>1279786542+delay) and mod(druleid,1)
            =0 and druleid between 000000000000000 and 099999999999999]
            2893:20100722:161542.994 Database is down. Retrying in 10 seconds
            2860:20100722:161652.962 [Z3005] Query failed: [2006] MySQL server has gone away [select hostid,proxy_hostid,host,useip,ip,
            order by hostid]
            2860:20100722:161652.962 Database is down. Retrying in 10 seconds
            2893:20100722:161652.998 [Z3005] Query failed: [2006] MySQL server has gone away [select druleid,iprange,name,unique_dcheck
            id from drules where proxy_hostid=0 and status=0 and (nextcheck<=1279786612 or nextcheck>1279786612+delay) and mod(druleid,1)
            2893:20100722:161652.998 Database is down. Retrying in 10 seconds
            2860:20100722:161802.967 [Z3005] Query failed: [2006] MySQL server has gone away [select hostid,proxy_hostid,host,useip,ip,
            order by hostid]
            2860:20100722:161802.967 Database is down. Retrying in 10 seconds
            2893:20100722:161803.003 [Z3005] Query failed: [2006] MySQL server has gone away [select druleid,iprange,name,unique_dcheck
            id from drules where proxy_hostid=0 and status=0 and (nextcheck<=1279786683 or nextcheck>1279786683+delay) and mod(druleid,1)
            2893:20100722:161803.003 Database is down. Retrying in 10 seconds
            2860:20100722:161912.971 [Z3005] Query failed: [2006] MySQL server has gone away [select hostid,proxy_hostid,host,useip,ip,
            order by hostid]
            2860:20100722:161912.971 Database is down. Retrying in 10 seconds
            2860:20100722:162022.975 [Z3005] Query failed: [2006] MySQL server has gone away [select hostid,proxy_hostid,host,useip,ip,
            order by hostid]
            2860:20100722:162022.975 Database is down. Retrying in 10 seconds
            2884:20100722:162047.941 Executing housekeeper
            2884:20100722:162053.248 Deleted 0 records from history and trends
            2860:20100722:162132.980 [Z3005] Query failed: [2006] MySQL server has gone away [select hostid,proxy_hostid,host,useip,ip,
            order by hostid]
            2860:20100722:162132.980 Database is down. Retrying in 10 seconds
            2860:20100722:162242.984 [Z3005] Query failed: [2013] Lost connection to MySQL server during query [select hostid,proxy_hos
            tid,host,useip,ip,dns,port,status,useipmi,ipmi_ip, ipmi_port,ipmi_authtype,ipmi_privilege,ipmi_userna me,ipmi_password,maintena
            nce_status,maintenance_type,maintenance_from,error s_from,available,disable_until,snmp_errors_from,sn mp_available,snmp_disable
            _until,ipmi_errors_from,ipmi_available,ipmi_disabl e_until from hosts where status in (0) and hostid between 000000000000000 a
            nd 099999999999999 order by hostid]
            2860:20100722:162242.984 Database is down. Retrying in 10 seconds
            2860:20100722:162352.988 [Z3005] Query failed: [2006] MySQL server has gone away [select hostid,proxy_hostid,host,useip,ip,
            order by hostid]
            2860:20100722:162352.988 Database is down. Retrying in 10 seconds
            2860:20100722:162502.993 [Z3005] Query failed: [2006] MySQL server has gone away [select hostid,proxy_hostid,host,useip,ip,
            order by hostid]
            2860:20100722:162502.993 Database is down. Retrying in 10 seconds
            2860:20100722:162612.997 [Z3005] Query failed: [2006] MySQL server has gone away [select hostid,proxy_hostid,host,useip,ip,
            order by hostid]
            2860:20100722:162612.997 Database is down. Retrying in 10 seconds
            2860:20100722:162723.002 [Z3005] Query failed: [2006] MySQL server has gone away [select hostid,proxy_hostid,host,useip,ip,
            order by hostid]
            2860:20100722:162723.002 Database is down. Retrying in 10 seconds
            2884:20100722:172153.250 Executing housekeeper
            2884:20100722:172158.562 Deleted 0 records from history and trends
            zabbix_agentd.log
            2902:20100722:151945.054 Zabbix Agent started. Zabbix 1.8.2 (revision 11211).
            2902:20100722:151945.055 Listener failed with error: Cannot bind to port 10050 for server [ANY]. Error [Address already in
            use]. Another daemon already running on this port ?.
            [root@localhost tmp]# ps -ef |grep zabbix
            zabbix 2194 1 0 10:41 ? 00:00:00 ./zabbix_agentd
            zabbix 2195 1 0 10:41 ? 00:00:00 ./zabbix_agentd
            zabbix 2858 1 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2860 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2861 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2862 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2865 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2867 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2869 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2871 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2873 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2875 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2877 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2879 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2881 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2883 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2884 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2887 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2888 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2891 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2893 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2895 2858 0 15:19 ? 00:00:00 ./zabbix_server
            zabbix 2897 2858 0 15:19 ? 00:00:00 ./zabbix_server
            root 3205 1759 0 17:39 pts/1 00:00:00 grep zabbix
            [root@localhost tmp]# ps -ef |grep mysql
            root 2813 1 0 15:19 pts/1 00:00:00 /bin/sh ./bin/mysqld_safe --datadir=/usr/local/mysql/data --pid-file=/usr/local/mysql/data/localhost.pid
            mysql 2843 2813 0 15:19 pts/1 00:00:07 /usr/local/mysql/bin/mysqld --basedir=/usr/local/mysql --datadir=/usr/local/mysql/data --user=mysql --pid-file=/usr/local/mysql/data/localhost.pid --skip-external-locking --port=3306 --socket=/tmp/mysql.sock
            root 3212 1759 0 17:41 pts/1 00:00:00 grep mysql
            • hipikll
              • Dec 2008
              • 12
              note, that FRONTEND (webpage) does not depend on status of zabbix server.
              It does not matter if your zabbix server is running or not, front page has to be accessible.
              From your post, I can see, that zabbix server is running, but has problem with mysql.
              Is your mysql running?
              Did you prepared zabbix DB in mysql?
              Did you edit zabbix_server.conf and added correct DB entries (DBname, DBuser, DBpass).
              Did you follow the guide for installation?
              • MrKen
                • Oct 2008
                • 652
                See the last post in this thread for a possible solution to your mysql problem
                MrKen
                • zabbixnewbie
                  • Jul 2010
                  • 28
                  [root@localhost tmp]# netstat -an |grep LISTEN|grep 3306
                  tcp 0 0 0.0.0.0:3306 0.0.0.0:* LISTEN
                  /etc/zabbix/zabbix_server.conf
                  LogFile=/tmp/zabbix_server.log
                  PidFile=/tmp/zabbix_server.pid
                  DBName=zabbix
                  DBUser=zabbix
                  DBPassword=zabbix
                  DBSocket=/tmp/mysql.sock
                  Different messages on /tmp/zabbix_server.log after i do something on mysql
                  5611:20100723:093041.284 Starting Zabbix Server. Zabbix 1.8.2 (revision 11211).
                  5611:20100723:093041.284 **** Enabled features ****
                  5611:20100723:093041.284 SNMP monitoring: NO
                  5611:20100723:093041.284 IPMI monitoring: NO
                  5611:20100723:093041.284 WEB monitoring: YES
                  5611:20100723:093041.285 Jabber notifications: NO
                  5611:20100723:093041.285 ODBC: NO
                  5611:20100723:093041.285 SSH2 support: NO
                  5611:20100723:093041.285 IPv6 support: NO
                  5611:20100723:093041.285 **************************
                  5613:20100723:093041.294 server #1 started [DB Cache]
                  5614:20100723:093041.295 server #2 started [Poller. SNMP: NO]
                  5616:20100723:093041.297 server #3 started [Poller. SNMP: NO]
                  5618:20100723:093041.299 server #4 started [Poller. SNMP: NO]
                  5620:20100723:093041.302 server #5 started [Poller. SNMP: NO]
                  5622:20100723:093041.304 server #6 started [Poller. SNMP: NO]
                  5624:20100723:093041.306 server #7 started [Trapper]
                  5626:20100723:093041.307 server #8 started [Trapper]
                  5628:20100723:093041.309 server #9 started [Trapper]
                  5630:20100723:093041.310 server #10 started [Trapper]
                  5632:20100723:093041.312 server #11 started [Trapper]
                  5634:20100723:093041.314 server #12 started [ICMP pinger]
                  5636:20100723:093041.315 server #13 started [Alerter]
                  5638:20100723:093041.318 server #14 started [Housekeeper]
                  5638:20100723:093041.318 Executing housekeeper
                  5640:20100723:093041.319 server #15 started [Timer]
                  5641:20100723:093041.321 server #16 started [Poller for unreachable hosts. SNMP: NO]
                  5644:20100723:093041.324 server #17 started [HTTP Poller]
                  5646:20100723:093041.328 server #18 started [Discoverer. SNMP: NO]
                  5648:20100723:093041.332 server #19 started [DB Syncer]
                  5650:20100723:093041.334 server #20 started [Escalator]
                  5611:20100723:093041.336 server #0 started [Watchdog]
                  Is the SNMP and Jabber is a must?because i am installing using following command;
                  Still cannot access to WEB Interface
                  http://<serverIP>:10051 ---> return a page with word "OK"
                  I realise the previous error on mysql happen when i startup the agentd.
                  Anyone can tell me what is going on here?
                  • zabbixnewbie
                    • Jul 2010
                    • 28
                    Is Apache is a must for WEB Interface?
                    I dont have apache
                    • MrKen
                      • Oct 2008
                      • 652
                      I dont have apache
                      Answer = http://www.zabbix.com/documentation/1.8/manual/installation/requirements#software_requirements
                      snmp is only required if you plan to monitor with snmp (i.e switches, routers, printers, etc.)
                      jabber is only required if you want 'pop-up' instant messaging.
                      MrKen
                      • Bennie
                        • Feb 2010
                        • 73
                        After you setup apache don't connect to another port. Zabbix frontend is just as any other webpage and can be placed in any normal virtual host setup in apache.
                        • zabbixnewbie
                          • Jul 2010
                          • 28
                          Do you mean if I want to access the Web Interface i must install apache in my zabbix server? It is not mention in the manual.
                          Or is it because i am pointing to the wrong path for my URL.
                          Anyone can correct my configuration?
                          • zabbixnewbie
                            • Jul 2010
                            • 28
                            MrKen
                            Thanks. After i change the wait_timeout instance, it doesnt show the error anymore but i still havent figure out why is the messages come out after i start the agentd.
                            Is it because of application internal connection to the server?
                            • Bennie
                              • Feb 2010
                              • 73
                              #15
                              As stated by mrken:
                              http://www.zabbix.com/documentation/...e_requirements
                              You NEED apache running to be able to run the interface. Zabbix does not provide a lone daemon for their webinterface.
