Zabbix active agent check fails on 1 item
  • jzondervan
    • Jul 2010
    • 19
    Strange problem: Since today one of the windows-agents fails to check a service. It worked smoothly yesterday, nothing has changed. I already restarted the agent but no good.
    Log shows this:
    5180:20100722:110942.517 JSON before sending [{
    "request":"agent data",
    "data":[
    "host":"BNIT01",
    "key":"service_state[ekrn]",
    "value":"0",
    "clock":1279789777},
    "host":"BNIT01",
    "key":"system.cpu.util[]",
    "value":"1.850000",
    "clock":1279789777}],
    "clock":1279789782}]
    5180:20100722:110942.520 JSON back [{
    "response":"success",
    "info":"Processed 1 Failed 1 Total 2 Seconds spent 0.000037"}]
    5180:20100722:110942.521 In check_response({
    "info":"Processed 1 Failed 1 Total 2 Seconds spent 0.000037"})
    All other items work fine, it's just the service_state that produces no data. Anyone knows how to resolve this issue?
  • jzondervan
    • Jul 2010
    • 19
    Solved it by deleting the item (disabling and activating did not work) and recreating it. Still worried, this shouldn't happen, should it?
