Status of Zabbix. Running? No
  • bernt
    • Dec 2004
    Hi!
    I have installed zabbix 1.0 and started zabbix with the command ./zabbix_suckerd.
    The command ps-aux gives
    zabbix 10070 0.0 1.1 4276 1408 ? S 12:00 0:00 ./zabbix_suckerd
    zabbix 10072 0.0 1.1 4276 1396 ? S 12:00 0:00 ./zabbix_suckerd
    zabbix 10073 0.0 1.1 4276 1392 ? S 12:00 0:00 ./zabbix_suckerd
    zabbix 10074 0.0 1.1 4276 1404 ? S 12:00 0:00 ./zabbix_suckerd
    zabbix 10081 0.0 1.2 4332 1532 ? S 12:00 0:00 ./zabbix_suckerd
    So I guess it's running. Or?
    In the webbinterface, STATUS OF ZABBIX i get.
    Is zabbix_trapperd running ? No
    I added a host and set it up to test http as simple test but nothing happens.
    I'm new to Zabbix and fairly new to Linux.
    Best Regards
    /Bernt
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Start zabbix_trapperd to get rid of this problem
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • bernt
      • Dec 2004
      ups, I mean
      Is zabbix_suckerd running ? No
      Sorry.
      • bernt
        • Dec 2004
        Hi again!
        Still got "Is zabbix_suckerd running ? No" in STATUS OF ZABBIX.
        But it's no problem to monitor hosts, get statistics and alerts so everything is working.
        Best Regards
        /Bernt
        Last edited by bernt; 10-12-2004, 14:35. Reason: Moved my questions to help forum.
        • avenger
          • Oct 2004
          • 10
          I have the same problem on few linux servers running Zabbix.
          In my case this is caused by GRSecurity patch on the kernel - it makes impossible for non-root account to view processes that it does not own.
          So, please check if the user from which apache is running can view processes correctly
          In my case - I am using crossmonitoring of all Zabbix servers - and making "ps" command from agentd conf file.
          • Rudolf
            • Dec 2004
            • 90
            Same problem
            Hi there,
            I have the same problem. Zabbix is running correctly, but I get the status message "No". I run Fedora Core 3 Linux. The problem is the permission for the exec command in report1.php. Instead of experimenting with permissions I just changed the php file, so no matter if zabbix is running or not, I get status Yes. Not the best solution, but it doesnt scare all people.
            • bernt
              • Dec 2004
              Hi!
              I got it to work. Just change safe_mode to off in php.ini and restart apache.
              Thanks for your help.
              Best Regards
              /Bernt
              • denso
                • Sep 2005
                • 32
                Sugestion
                I have seen this problem on redhat machines (RHEL & FC) and it makes a world of difference if you turn off SEL linux by opening an xterminal and typing system-config-secyritylevel and turning off SELlinux and rebooting once. then the processes work because sel is not blocking them similar to GRSec
