status up/down device cisco
  • fabiomc
    • Nov 2009
    • 53
    Hi
    i want to monitore only the status up or down of device cisco.
    im not interested about traffic/flow
    how can i do it?
    thanks
    Fabio
  • MrKen
    • Oct 2008
    • 652
    First you need to enable snmp-server in your cisco device.
    You can use ifOperStatus
    OID = .1.3.6.1.2.1.2.2.1.8.<port>
    e.g .1.3.6.1.2.1.2.2.1.8.10101
    MrKen
    • fabiomc
      • Nov 2009
      • 53
      without able snmp on device cisco, there is not other method to know the status of router cisco ? for example with
      some ping to router cisco ?
      thanks
      • jzondervan
        • Jul 2010
        • 19
        icmp ping
        You could just use a simple check and ping it to see if it's accessible..
        icmpping[<ip>,<count>,<interval>,<size>,<timeout>]
