CPU usage & Memory usage for IIS & SQL server
  • dunedin
    • Dec 2005
    • 12
    Has anyone know how to check (monitor) CPU usage (process %) and memory usage (overall) for IIS & SQL server on a windows server(client machines) ??
    Couldn't find any documentation for the above. Can anyone advise ?
  • NomenNescio
    • Jan 2009
    • 70
    Bump, does anyone know how to monitor IIS? I can't find anything IIS related with typeperf -qx.
    • NomenNescio
      • Jan 2009
      • 70
      bump >_> doesn't anyone monitor IIS?
      • jroberson
        • May 2008
        • 124
        I've read somewhere about IIS Performance Counters and I know there are SQL Server performance counters. You might check MS' knowledge base about performance counter extensions (add and or repairing). The IIS process might also just be listed in the perfcounter "\Process(<name of application>)\% Processor Time"
        • caarts
          • Aug 2008
          • 37
          Never done any IIS monitoring (yet) but I can tell you that the tips and tricks in this topic for monitoring MS SQL are very usefull :
          • Calimero
            • Nov 2006
            • 481
            Well so far we only use this:
            IIS Current Anonymous Users 	perf_counter[\Web Service(_Total)\Current Anonymous Users]
            IIS Current Connections 	perf_counter[\Web Service(_Total)\Current Connections]
            IIS Current NonAnonymous Users 	perf_counter[\Web Service(_Total)\Current NonAnonymous Users]
            IIIS Get Requests/s 	perf_counter[\Web Service(_Total)\Total Get Requests]
            IIS Head Requests/s 	perf_counter[\Web Service(_Total)\Total Head Requests]
            IIS Post Requests/s 	perf_counter[\Web Service(_Total)\Total Post Requests]
            Total requests are stored as "Delta (speed per second)" as perfmon gives the total amount of hits. There are also native "Get/Post requests per second" metrics in perfmon but they cannot be used from zabbix as perfmon only updates those values when you run it. If you run perfmon.exe and display the native "requests per second" items and at the same time tell zabbix_agent to poll those metrics, everything will be fine. But once you close permon.exe on the monitored host zabbix_agent will be given and thus will send wrong statistics. There may be other metrics of interest but I haven't had time lately to dig.
            I'll take a look at the thread you linked, caarts. Thanks !
            • robsontecinfo
              • Aug 2009
              monitor IIS
              Good afternoon,
              I wonder if you can track the hits to access an IIS server, what ip accessed, number of hits and pages visited?
              Thank you.
