Item which is a sum of Other Item
  • ricamz
    • May 2010
    • 15
    Hi there.
    I have two questions.
    1) I have an item A which count the number of transactions that were made in a given database every minute. And this item works fine.
    What I want now is to have another item B which is the daily sum of item A.
    I have tried grpsum and even having an sql sum of the database. But both give me errors at some point.
    2) I want to have a user that can only have access to one host and not a group of hosts. How can I do that?
    Regards,
    Ricardo
  • alixen
    • Apr 2006
    • 474
    You should use a calculated item: http://www.zabbix.com/documentation/...lculated_items
    Basically, you will define it as:
    sum("host:A",86400)
    Access rights are defined on a whole group, not on a specific host.
    As a workaround, I'd suggest to create a new host group with only the host you want and change user rights accordingly.
    Regards,
    Alixen
    http://www.alixen.fr/zabbix.html
    • ricamz
      • May 2010
      • 15
      Thanks alixen.
      But if we sum 86400 seconds back from now it will sum transactions that happened yesterday (if we are in the beginning of the day).
      • alixen
        • Apr 2006
        • 474
        Thanks alixen.
        Sorry, I think that I misunderstood your question.
        Do you want:
        1. an item that is computed once a day, preferably at the end of the day and give you the sum for all day
        2. an item that will repeatedly compute the sum for current day, basically it will start at 0 at 00:00 and increase all day until 23:59
        My solution could be adapted in first case by playing with flexible intervals. For second case, I don't think there is an easy solution with Zabbix formulas.
        Regards,
        Alixen
        • ricamz
          • May 2010
          • 15
          It is the second one.
          I have done something like making a query in sql (in zabbix db) that sums all the values in that day for the item.
          But for some reason one day it stopped working. I think it's more an hack than a solution, but for few weeks it worked out well.
          • waardd
            • Aug 2014
            • 82
            Originally posted by alixen
            • an item that is computed once a day, preferably at the end of the day and give you the sum for all day
            I'm looking for a way tot calcultae items at a daily basis at the beginning of the day the previous day, or at the end of the day that day.
            Is there a way i can use grpsum or something to calculate a daily sum?
