Include one template to host many times
  • rekby
    • Jul 2010
    • 91
    I need to monitor some tens servers, in each server run 3-5 web-servers.
    every web-server have test domain name:
    test-ServerNumber-WebServerType.domain
    I have template BASE with item HttpAvailable. It is external check with key script[{$SERVER} {$TYPE}].
    I create two subtemplates: CHILD-1 and CHILD-2, each link to BASE and define macros {$TYPE} (in CHILD-1 - {$TYPE} = 1, in CHILD-2 {$TYPE} = 2).
    I need create host SERVER-1, link it to CHILD-1 and CHILD-2 and define macros {$SERVER}=1, but i can't do it with warning: "Template with item key [script[{$SERVER} {$TYPE}]] already linked to host.
    In result i want define base template for web-server one time (with items, triggers, ...) and add it to one host many times with different parameters.
    How I can do it?
  • richlv
    • Oct 2005
    • 3112
    i don't think you can do it currently that way. most likely you would have to create new host for each website (which isn't a huge problem usually), then override the macro on the host level - and that way you have only single template to take care of
