Bug? Calculated item
  • bobrivers
    • Feb 2007
    • 115
    I'm trying to add a calculated item that gets tha MAX item value from another host in order to do some conculations (zabbix 1.8.2 - centos 5.5)
    So I created an item with the following:
    host:hostA
    type:calculated
    key:xpto
    expression:max("hostB:monitoredItem")
    Notice that I'm adding an item in hostA, trying to get a value from hostB.
    But, when zabbix tries to get it, I got the following error msg: Can not evaluate function [max()]
    If I change the expression to last("hostB:monitoredItem") it works.
    Reading zabbix manual, it states that I can use anyone of the functions supported by triggers, that includes max.
    So my question is: Am I missing something? Why max isn't working?
    TIA,
    Bob
  • richlv
    • Oct 2005
    • 3112
    looks like you are missing a parameter for max, one that defines at how long period it should look at
