MySQL library not found during config stage
  • vibe83
    • Aug 2010
    hey guys,
    understand that this qns is being raised before. However i've not come across a solution that is working for me yet.
    Am i trying to install zabbix1.8.2 on a REL5 machine. But so far, i keep coming across this, and im using this mySQL. I have the below installed. please enlighten me on what im missing. TIA, appreciate some help.
    MySQL-client-community-5.1.46-1.rhel5
    MySQL-server-community-5.1.46-1.rhel5
    php-mysql-5.3.2-2.el5.remi
    mysqlclient16-5.1.30-1.el5.remi
  • MrKen
    • Oct 2008
    • 652
    You need to install mysql-devel
    MrKen
    • vibe83
      • Aug 2010
      Mr Ken, thanks for the reply, sorry, but can i use just about any version of the sql-devel? or it has to be the same as my MySQL-community that im using?
      • MrKen
        • Oct 2008
        • 652
        Not really sure about that. I just yum install.
        This is what I have installed (not sure why mysql-devel is listed twice)
        mysql-server-5.0.45-7.el5
        mysql-5.0.45-7.el5
        mysql-devel-5.0.45-7.el5
        php-mysql-5.1.6-20.el5_2.1
        mysql-5.0.45-7.el5
        Sorry, maybe that doesn't help much.
        • vibe83
          • Aug 2010
          Hey mrKen,
          No worries, i just installed the devel. which is of a different version. somehow the configuration goes past that portion. so i'll just give it a shot, if it poses to some issue afterwards i'll just update the entire thing to a newer version.
          Now its giving me errors like no jabber and libcurl. i'll run through the same process; getting the libs installed and see if it works.
          Thanks!
          • vibe83
            • Aug 2010
            Libcurl not found???
            Still trying to install zabbix.... now its saying that libcurl library is not found. any idea?
            checking for curl-config... /usr/bin/curl-config
            checking for the version of libcurl... 7.15.5
            checking for libcurl >= version 7.13.1... yes
            checking for main in -lcurl... no
            configure: error: Not found libcurl library
            Notice it says checking of libcurl version. which again, shows that it is installed already...so any advise on what libcurl library its referring to ?
