Z green though zabbix agent not running
  • dlinsenmaier
    • Aug 2010
    Hi all of you,
    I use Zabbix 1.8.2 on Red Hat (Server)
    I use Zabbix 1.8.2 on HP-UX 11.23 (Client)
    I installed zabbix agent on a HP-UX client. So the client was discovered and put into a template by simple_check: tcp,<zabbixport>. -> Z turned green.
    So this is quite as it should be ...
    BUT
    After stopping and deinstallation of zabbix agent on this client. Zabbix still "thinks" that there is an agent running on this system. I removed the client manually from the template (serveral times) but the action which makes a simple_check tcp,<zabbixport> puts it back into this template again and again.
    In addition Z stays green.
    Any ideas what's wrong here?
    Thanks & Cheers,
    Dierk
