PHP Timezone Fail
  • Combusted
    • Aug 2010
    PHP Timezone Fail
    Hi all,
    I'm trying to setup a 1.8.2 Zabbix server on Ubuntu Server 10.04.
    I've got as far as the installation webGUI so far, but it's failing on
    PHP Timezone.
    I've edited the .ini to make it
    ;date.timezone = Europe/London
    Which appears to be correct?
    I've already checked the following page to make sure it's the correct spacing/capitalization;
    and I've looked at this thread;
    Where they mentioned changing setup.inc.php
    However they are using 1.6, and it seems the
    empty($tmezone),
    Is not in my setup.inc.php file, however I found a requirements.php file where empty($tmezone), was, but it already had a comma in like they suggested...
    Any ideas?...
    I've spent days on this so far... haha...
  • nelsonab
    • Sep 2006
    • 1233
    If that's the only data.timezone statement in your file, it's commented out. In the php.ini files a semi-colon at the start of a line denotes a comment.
    RHCE, author of zbxapi
    • Combusted
      • Aug 2010
      Really?
      God... that's awful of me...
      Thanks very much!! I'll try it out.
      Also, as for the
      PHP Database Support - Fail,
      Is there any common resolution for this?
      The strange thing being this said OK before I changed the values from 60 to 300 of the others...
      • nelsonab
        • Sep 2006
        • 1233
        Sounds like you may be missing some libraries. Perhaps the equivalant of php-<db of choice> (example: php-mysql) has not been installed. Often you need to install a few extra rpms on CentOS like php-gd, php-bc, php-mysql and so forth. Has a search of the forums not yielded any answers suitable for your situation?
        • Combusted
          • Aug 2010
          Hi, just thought I'd say this has now been resolved.
          I had to remove the semi-colon in front of the line.
          And for the PHP Database support, I had to apt-get install php5-mysql
          Thanks for the help!
