Play a Sound feature does not work
  • QwErTy_LoGiC
    • Feb 2010
    • 66
    Hello all,
    I am trying out all the new features Zabbix 1.8.3 has to offer and I cannot get the play a sound feature in the GUI messaging to work. When I click play, no sound comes out. It does not matter which sound I select or if the sound is checked or not.
    I may have missed something. Is there a library necessary for sound playback that we should have at compile time? I'm kinda stumped here...
    Thanks for any input!
  • QwErTy_LoGiC
    • Feb 2010
    • 66
    Works(somewhat) in Firefox, Does not in Chrome and IE8
    Ok I tested it in Chrome and in IE8 without success, I then installed Firefox 3.6.8 and the play button works (except when I select alarm_ok sound).
    In Chrome, in the element inspector, I get a
    <input> is not allowed inside <tbody>. Inserting <input> before the <table> instead.
    error somewhere...
    • richlv
      • Oct 2005
      • 3112
      hmm. it didn't work for me in opera either, but i didn't pay much attention to that. please, report this problem on the tracker - thanks.
      • nelsonab
        • Sep 2006
        • 1233
        It probably works for Aly using his beloved IE6...
        RHCE, author of zbxapi
        • QwErTy_LoGiC
          • Feb 2010
          • 66
          Reported
          Reported > ZBX-2896
          • Aly
            ZABBIX developer
            • May 2007
            • 1126
            By default IE should play alarms, but in some configurations it doesn't due to it can't play sound by him self, IE opens Windows Media Player through activeX. If sound doesn't play, try to install QuickTime it should help for IE.
            Chrome can't play wav files (but by specifications it should), others browsers should play without an issues. For chrome you'll probably need to convert audio files from wav to ogg.
            Zabbix | ex GUI developer
            • sire
              • Jul 2010
              • 210
              Doesn't play sound in Firefox on CentOS 5.5 either.
              Regards,
              Sergey Syreskin
              Monitored hosts: 2646 / Active items: 23604 / Server performance: 765.74
              Temporary out of Zabbix business
              • Zaniwoop
                • Jan 2010
                • 232
                I have two PCs:
                1) Windows 7 with Firefox 3.6, it works
                2) Windows XP with Firefox 3.6, it doesn't work
                • whit3h0rse
                  • Aug 2014
                  • 18
                  Zabbix 2.4 also has problems with playing sounds, it works when I manually play it from settings but Zabbix he rarely plays sound with triggers. I have tried Chrome and Firefox (newest) on Linux and Widnows. How do I troubleshoot this?
