Compile problem
  • jgorres
    • Aug 2010
    Compile problem
    Good morning, everybody,
    I am trying to compile zabbix 1.8.3 under Ubuntu 8.04.4 LTS
    I use the following command:
    ./configure --enable-server --with-mysql --with-net-snmp --with-jabber --with-libcurl # for MySQL + Jabber + WEB monitoring
    The shell returns:
    checking for a BSD-compatible install... /usr/bin/install -c
    checking whether build environment is sane... yes
    checking for a thread-safe mkdir -p... /bin/mkdir -p
    checking for gawk... gawk
    checking whether make sets $(MAKE)... yes
    configure: Configuring
    checking whether make sets $(MAKE)... (cached) yes
    checking build system type... x86_64-unknown-linux-gnu
    checking host system type... x86_64-unknown-linux-gnu
    checking for gcc... gcc
    checking for C compiler default output file name...
    configure: error: C compiler cannot create executables
    See `config.log' for more details.
    config.log states:
    |   return 0;
    configure:2916: error: C compiler cannot create executables
    [lines deleted by me, Jörn]
    configure: exit 77
    Can somebody please assist?
    Kind regards,
    Jörn.
  • walterheck
    • Jul 2009
    • 153
    Let Me Google That For You (LMGTFY): for all those people who find it more convenient to bother you with their question rather than search it for themselves.
    First result, halfway down the page..
    Free and Open Source Zabbix Templates Repository | Hosted Zabbix @ Tribily (http://tribily.com)
    • jgorres
      • Aug 2010
      Hi Walter,
      For a Linux beginner not everything is obvious (however I knew the lmgtfy link before and I really appreciate it). It is just the second or third time I compiled a program myself.
      Thanks, for your hint; it pointed me into the correct direction. I could solve all following problems (mainly missing libs).
      So, Zabbix is running and all future question will concern how to use it ;-)
      Thanks for your help.
      Kind regards,
      Jörn.
