Map does not function on 1.8.3
  • yjeff
    • Aug 2008
    • 12
    Configure-->map-->create map-->add element, click the icon a popup menu displayed. But after you changed the attribute of the element, you click the "Apply" button and it does not work. Eveything is same as before. Why ?
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    First thing to do is to add icons in zabbix frontend.
    And what kind of parameters you are changing?
    Zabbix | ex GUI developer
    • yjeff
      • Aug 2008
      • 12
      Thank you for your reply.
      I installed the zabbix according the installation guide and just copy the zabbix.inc.php file to /var/www/html/zabbix/conf/. I did not change any parameter.
