Helo!
I've stange problem with zabbix on few host on one (the same) Item.
This Item is on queue over 5 days.. i can check it from zbbix server (zabbix_get return correct value)...but on Latest data I've incorect value and last check has been done 5 days ago...
Here is log from zabbix server...
29759:20100825:203109.883 Disabling ZABBIX host [MyHOST]
29759:20100825:222243.487 Item [MyHOST:ZabbixAgentItem] error: Get value from agent failed: Cannot connect to [10.10.1.15:10050] [Interrupted system call]
29759:20100826:050238.939 Item [MyHOST:ZabbixAgentItem] error: Get value from agent failed: Cannot connect to [10.10.1.15:10050] [Interrupted system call]
29759:20100826:061153.805 Item [MyHOST:ZabbixAgentItem] error: Get value from agent failed: Cannot connect to [10.10.1.15:10050] [Interrupted system call]
29759:20100826:063230.373 Item [MyHOST:ZabbixAgentItem] error: Get value from agent failed: Cannot connect to [10.10.1.15:10050] [Interrupted system call]
29759:20100826:065108.575 Enabling ZABBIX host [MyHOST]
As you can see all errors occured when server is off. I ve no error with this Item after "Enabling Zabbix host" and only "ZabbixAgentItem" has been checking when the zabbix agent (and server) was disabled.
This problem occurod on few host and is the same.
ZabbixAgentItem works corectly on over 50 host..and only few host has this error...
