Big values from Switch with snmpv1
  • root_master
    • Dec 2005
    • 18
    i use zabbix 1.1beta4 and want get the traffic information from a snmp v1 switch. (snmpv2 does not supported)
    snmpget works fine
    snmpget -v 1 -On -c monitor switch01 ifInOctets.213
    .1.3.6.1.2.1.2.2.1.10.213 = Counter32: 1131069068
    but in zabbix it will be show as 1000000000 (if it compiled with gcc 4.0) or 0 (if it compiled with gcc-3.3)
    i've read in the forum, that i need the checks_snmp.c from the cvs...
    but the version from cvs is the same like the 1.1beta4.
    does anybody a idea ? because i cant use snmp v2 (with snmpv2 on a other switch works fine).
    thank a lot
    root_master
  • pdwalker
    • Dec 2005
    • 166
    If you cannot find a fix for handling the big numbers, you might want to try using a decimal multiplier to bring the number down to something smaller so you can at least graph them, say.. .001? .000001?
    - Paul
    • root_master
      • Dec 2005
      • 18
      yes, i can reset the switch. but i'll don't do this.
      with snmpv2c it works fine.
      maybe it is a varables problem with int.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        snmpget works fine
        It is very strange. I do not understand how GCC version may affect this functionality. Do you see these values in ZABBIX database, table history?
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • root_master
          • Dec 2005
          • 18
          yes.
          those values are stored in the database.
