Icons doesn't work in beta4
  • root_master
    • Dec 2005
    • 18
    The icons doesn't work in version 1.1beta4.
  • scotti
    • Dec 2005
    • 32
    what's your configuration;and how about the error?
    the icons working correctly in my box.
    • sargezim
      • Jul 2005
      Jepp they wont work for a fresh installation, because the sql data is missing in data.sql .
      To fix it by yourself:
      Go to /create there you'll find an images folder and a images.sql . Edit your images.sql, setting the path inside the insert statements ( /home/zabbix/zabbix/create ) to ( /path/to/your/zabbix/create ).
      Execute the file with mysql zabbix < images.sql or similiar
      You should be done.
      It seems that you can easily import your own Icons with a simple query, too . Nice.
