Monitoring with proxy broke
  • nocturn
    • Nov 2008
    • 16
    #16
    Originally posted by tchjts1
    Yeah, I am a bit lost on what advice to give you next. I haven't played with 1.8.3 too much yet, but I do know they introduced a new mode for the proxy "passive". Take a look at Administration --> DM and the second column over for the proxy is "Mode". Mine is set to "Active" on my 1.8.3 setup and all is working fine.
    Outside of what I have listed in the previous steps, I don't know what else to tell you on this. Maybe someone else has a thought or maybe a dev can chime in with some steps to take.
    Set to active here too...
    Thanks for your help
    • nocturn
      • Nov 2008
      • 16
      #17
      Anyone?
      I tried setting it to the new passive mode and the result is identical.
      The connection between Zabbix and the proxy is OK, the connection between the proxy and the agent is OK, but no updates are coming in...
      • nocturn
        • Nov 2008
        • 16
        #18
        Originally posted by pedrie123
        I have upgraded zabbix proxy to 1.8.3 now need to check the debug level...after restart I was late and couldnt just look into the first lines..gotta do it all again?
        Do you have the same problem as I?
