I have upgraded from zabbix 1.6.5 to 1.8.3, subsequently unable to create trigger or import trigger to newly created host.
Unable to create/import trigger after upgrade to zabbix 1.8.3
... and ?
any error message, does this happen with all triggers, what's the exact trigger expression that causes the problem ? -
Reply
I'm creating simple trigger for unavailability via icmpping item. Following are the extract from httpd's error log:
[Thu Sep 02 14:59:46 2010] [error] [client x.x.x.x] File does not exist: /var/www/html/zabbix/images/genereal, referer: http://y.y.y.y/zabbix/popup_trexpr.php
[Thu Sep 02 14:59:46 2010] [error] [client x.x.x.x] PHP Fatal error: Call to undefined function mb_internal_encoding() in /var/www/html/zabbix/include/classes/class.cjson.php on line 231, referer: http://y.y.y.y/zabbix/popup_trexpr.php
[Thu Sep 02 14:59:55 2010] [error] [client x.x.x.x] PHP Fatal error: Call to undefined function mb_strlen() in /var/www/html/zabbix/include/classes/class.cstringparser.php on line 53, referer: http://y.y.y.y/zabbix/triggers.php?s...Create+Trigger
[Thu Sep 02 14:59:55 2010] [error] [client x.x.x.x] File does not exist: /var/www/html/zabbix/styles/ie_default.css, referer: http://y.y.y.y/zabbix/triggers.phpComment
1. "genereal" looks suspicious. did you modify the frontend ?[Thu Sep 02 14:59:46 2010] [error] [client x.x.x.x] File does not exist: /var/www/html/zabbix/images/genereal, referer: http://y.y.y.y/zabbix/popup_trexpr.php
2. looks like php mbstring support is missing. see reports -> status of zabbix.
of course, make sure to use 1.8.3Comment
Love how a post from 5 years ago saves my bacon tonight.
After OS Security patching changed my PHP version, I found the answer in #2 above.Comment
