I _think_ there is a bug in zabbix proxy related to active checks and TEXT (at least) values.
Zabbix server - version 1.8.3 Linux 2.6
zabbix proxy - version 1.8.3 Solaris 8
zabbix agent - version 1.8.3 Solaris 8
I have client ( Solaris 8 ) monitored by a by a passive zabbix agent checks (CPU etc).
I wanted to add an active check , custom script
Script returns TEXT value "OK" or "FAIL" depending on state of metadevices.
So I added a line to zabbix_agentd.conf
I could see that script runs and sends a value to zabbix_proxy
also I could see that this value is received by proxy
then this value is missing when sent to server as well:
It seems to me ( please don't kick me if I am wrong ) - proxy_add_history_text() , loses a value, because value column in insert statement is empty string.
#!/bin/perl
my @mas=`/usr/sbin/metastat|/usr/bin/grep State:`;
my $Fail="NO";
foreach(@mas)
chomp($_);
s/\s+//g;
#DBG print "$_\n";
$i=$_;
if( $i ne "State:Okay" )
$Fail="YES";
#DBG print "Fail:$Fail\n";
if( $Fail eq "YES" )
print "FAIL\n";
exit 1;
else
print "OK\n";
exit 0;
UserParameter=solaris.disksuite,/opt/zabbix/bin/disksuite_status.pl
9052:20100907:125907.548 Before 9052:20100907:125907.548 Run remote command [/opt/zabbix/bin/disksuite_status.pl] Result [2] [OK]... 9052:20100907:125907.549 Sending back [OK]
22084:20100907:125907 In add_history(itemid: 29347,key:"solaris.disksuite",value_type:4,TEXT:[OK]) 22084:20100907:125907 In proxy_add_history_text() 22084:20100907:125907 Query [insert into proxy_history (itemid,clock,value) values (29347,1283853547,'')] 22084:20100907:125907 End of proxy_add_history
22081:20100907:125908 In connect_to_server() [10.150.23.11]:10051 [timeout:600]
22081:20100907:125908 In put_data_to_server() [datalen:797]
22081:20100907:125908 In send_data_to_server() [{
"request":"history data",
"host":"man301",
"data":[
"host":"app101",
"key":"system.cpu.switches",
"clock":1283853547,
"value":"2338899668"},
"host":"man301",
"key":"system.cpu.util[all,idle]",
"clock":1283853547,
"value":"94.255095"},
"host":"app202",
"clock":1283853547,
"value":"22976963124"},
"host":"www101",
"clock":1283853547,
"value":"68.384309"},
"host":"www202",
"clock":1283853547,
"value":"56.940407"},
"host":"www201",
"key":"icmpping",
"clock":1283853547,
"value":"0"},
"host":"www101",
"key":"solaris.disksuite",
"clock":1283853547,
"value":""}],
"clock":1283853548}]
22081:20100907:125908 In recv_data_from_server()
22081:20100907:125908 Received [{
"response":"success",
"info":"Processed 7 Failed 0 Total 7 Seconds spent 0.000312"}] from server
22081:20100907:125908 End of put_data_to_server():SUCCEED
