I have three nodes all running identical checks, with identical triggers. All three nodes report into a single master. When the triggers are set to problem, they show up properly in master. Actions on the master that are set up for each individual node are executed as expected.
However, if I set up an action and select the same trigger for all three nodes, with a trigger value of PROBLEM and a calculation type of AND ( (A and B and C) and D), and when the triggers are set on all three nodes, the action is not executed. They all show up in the trigger monitor as PROBLEM, so the central monitor knows that the trigger is set, but no action is ever taken, and no e-mail is sent.
Am I missing something?
Thanks,
Kenny
Thanks,
Kenny
