Is this a bug ? "Follow redirects" mark is disappeared.
  • spcblack
    • May 2009
    Hi, all...
    I'm using 1.8.2 on Linux kernel 2.6.9.
    As I mentioned in subject, I marked the "Follow redirects" check-box when I make a step of web scenario. But, it disappeared !! As I check out the DB table (httpstep), the value of "follow" field is "1" (selected) .
    Is this a bug or not ??
    Thanks in advance..
  • spcblack
    • May 2009
    Answer...
    I noticed that it was my fault !! It does not exists in Zabbix original source . It was the patched version. Sorry for all.
