in 1.8.2 it was possible to add a Trigger with an array without any problems. I have configured some of them and they are running fine.
Since we upgraded to 1.8.3 we are neither able to change this Triggers or add new ones like this.
A sample:
{XXXXX:zimbra[[antispam,antivirus,convertd,ldap,logger,mailbox,mt a,snmp,spell,stats]].last(0)}#0
Error:
Überflüssige Symbole gefunden: Prüfen Sie die Expression beginnend bei ' ].last(0)}#0 '
Host key does not exist. Prüfen Sie die Expression beginnend bei ' :zimbra[[antispam,antivirus,convertd,ldap,logger,mailbox,mt a,snmp,spell,stats]].last(0)}#0 '
As said, in 1.8.2 there was no Problem with Triggers like this. If i remove the second ] of the key, the first message disappears, but as it should, then it doesn't match the Host key any longer.
Any suggestions?
Thanks in advance.
A sample:
Error:
Any suggestions?
Thanks in advance.
