LDAP - search attribute
  • mvrk
    • Oct 2008
    • 71
    Is it possible to add to LDAP "Search attribute" something like this:
    ((uid)&(accountStatus=active))
    What i want is that only the users that have the field accountStatus = active be able to login into zabbix, is this possible?
  • kekieres
    • Nov 2010
    I think it's not possible. At least I've tried to build an LDAP filter with the field Attribute without success.
    I suppect the problem is here: Zabbix construct the LDAP query combining the Attribute field and the user that's doing the authentication
    (in Zabbix 1.8.2, in file $ZABBIX_HOME/zabbix/include/classes/class.cldap.php with that PHP sentence: 'userfilter'=> '(%{attr}=%{user})',
    That implies that in the attribute field you CAN ONLY put the LDAP attribute where the user name is stored. I believe there is no way to build that filter with the attribute field.
    I've been thinking about and maybe it makes sense if Zabbix interpret LDAP as just a way of doing the authentication, and the authorization is done at Zabbix level itself because, if the user is not in the Zabbix database and in a group it cannot loggin even if it can authenticate.
    May be someone from Zabbix Development Team could put a little light here and confirm or suggest a way of doing it.
