Have you tried to compile ZABBIX agent with AIX C compiler? It works on AIX 4.x and 5.0. I do not have available AIX 5.3, I cannot test it now.
Help needed : compilation on AIX 5.3 failed
compiling with gcc
If you like to compile the agent with gcc you have to following commands:
./configure --enable-agent
make
cd src/zabbix_agent/
gcc -g -O2 -o zabbix_agent zabbix_agent.o ../libs/zbxsysinfo/aix.o ../libs/zbxsysinfo/common.o ../libs/zbxsysinfo/file.o ../libs/zbxsysinfo/ntp.o ../libs/zbxsysinfo/system.o ../libs/zbxsysinfo/http.o ../libs/zbxsysinfo/aix/cpu.o ../libs/zbxsysinfo/aix/diskio.o ../libs/zbxsysinfo/aix/diskspace.o ../libs/zbxsysinfo/aix/inodes.o ../libs/zbxsysinfo/aix/kernel.o ../libs/zbxsysinfo/aix/memory.o ../libs/zbxsysinfo/aix/net.o ../libs/zbxsysinfo/aix/proc.o ../libs/zbxsysinfo/aix/sensors.o ../libs/zbxsysinfo/aix/swap.o ../libs/zbxsysinfo/aix/uptime.o ../libs/zbxlog/libzbxlog.a ../libs/zbxcrypto/libzbxcrypto.a ../libs/zbxnet/libzbxnet.a ../libs/zbxconf/libzbxconf.a ../libs/zbxcommon/libzbxcommon.a
make
gcc -g -O2 -o zabbix_agentd active.o cpustat.o diskdevices.o interfaces.o logfiles.o stats.o zabbix_agentd.o ../libs/zbxsysinfo/aix.o ../libs/zbxsysinfo/common.o ../libs/zbxsysinfo/file.o ../libs/zbxsysinfo/ntp.o ../libs/zbxsysinfo/system.o ../libs/zbxsysinfo/http.o ../libs/zbxsysinfo/aix/cpu.o ../libs/zbxsysinfo/aix/diskio.o ../libs/zbxsysinfo/aix/diskspace.o ../libs/zbxsysinfo/aix/inodes.o ../libs/zbxsysinfo/aix/kernel.o ../libs/zbxsysinfo/aix/memory.o ../libs/zbxsysinfo/aix/net.o ../libs/zbxsysinfo/aix/proc.o ../libs/zbxsysinfo/aix/sensors.o ../libs/zbxsysinfo/aix/swap.o ../libs/zbxsysinfo/aix/uptime.o ../libs/zbxlog/libzbxlog.a ../libs/zbxcrypto/libzbxcrypto.a ../libs/zbxpid/libzbxpid.a ../libs/zbxnet/libzbxnet.a ../libs/zbxconf/libzbxconf.a ../libs/zbxcommon/libzbxcommon.a
cd ../..
make
make install
For the server you have to find out by your self which librarys you need!
This error came into the code with the new autoconf, I think it was 1beata10.
Have funComment
use UserParameters
You can use Userparameters to get the missing values:
# cpu load
UserParameter=usr.cpu,uptime |cut -d, -f5
# diskio
UserParameter=usr.io.disk_r,iostat | grep hdisk | awk '{sum += $ 5} END {print sum}'
UserParameter=usr.io.disk_w,iostat | grep hdisk | awk '{sum += $ 6} END {print sum}'
# net load
UserParameter=usr.net.in[*],netstat -v $1 | grep Bytes | awk '{printf("%d", $ 4%2^24)}'
UserParameter=usr.net.out[*],netstat -v $1 | grep Bytes | awk '{printf("%d", $ 2%2^24)}'
# pagings
UserParameter=usr.paging[*],lsps -s $1 | grep % | awk '{printf("%d",$ 2)}'
UserParameter=usr.paging.total,svmon|grep 'pg space'|awk '{printf "%.0f\n",$3*4}'
UserParameter=usr.paging.used,svmon|grep 'pg space'|awk '{printf "%.0f\n",$4*4}'
UserParameter=usr.paging.free,svmon|grep 'pg space'|awk '{printf "%.0f\n",($3 - $4)*4}'
# proc count
UserParameter=usr.proc.cnt[*],ps -eaf |grep -v grep|grep -c $1
#cups
UserParameter=usr.cups.cnt[*],/usr/local/bin/lpstat -P $1 |wc -lComment
Impossible to compile Zabbix server on AIX 5.2
Hi Zabbix-users,
despite all your advice, I only managed to compile Zabbix agent on my AIX 5.2 server. This has been made with gcc.
So I try to compile the server part, an error appears with the "make" command :
I decided to install XLC (IBM C compiler for AIX), but still the same error.....Code:..... ..... Making all in zbxsms source='sms.c' object='sms.o' libtool=no DEPDIR=.deps depmode=aix /bin/sh ./../../depcomp xlc -DHAVE_CONFIG_H -I. -I. -I../../../include -g -c sms.c "sms.c", line 116.40: 1506-045 (S) Undeclared identifier CRTSCTS. make: The error code from the last command is 1. Stop.
Please help me !Comment
Unable to compile on AIX5.3
I'm trying to install Zabbix 1.1 agent onto my AIX 5.3ML3 system, and I've tried installing XLC and I continue to get the same make error as everyone else:
conf.a ../libs/zbxcommon/libzbxcommon.a -lnsl
collect2: ../libs/zbxsysinfo/libzbxsysinfo.a: not a COFF file
make: 1254-004 The error code from the last command is 1.
Do I need to tell it to look for xlc rather then gcc or will it do that automatically?Comment
zabbix user on AIX
I have my zabbix user setup thus ... "uid=901(zabbix) gid=1(staff)". Anyone have any different, is there anything in particular people have found that needs to be added/done to the zabbix user to make it work better ?? I seem to be getting data ok.
the only other thing that i think i will need to do is to add it to the oracle groups so it gain access to the DB's for monitoring.
ta
HComment
ZABBIX Agent on AIX 5L
Guys!
I had the same COF file problem in my AIX 5.3 on power, I give up to compile and to solve my problem, I used an AIX 5.1 compiled agent (http://www.zabbix.com/download2.php)
Extract the files zabbix_agent zabbix_agentd zabbix_sender to a folder as you wish
Configure the zabbix_agentd.conf and start the zabbix_agentd
Flex.limaComment
