Hi
Recently I did a maintenance procedure on Zabbix Server. MySQL zabbix database was very huge and I was able to reduce a lot.
Now I run Zabbix Server in one CentOS 5 box and MySQL zabbix database instance in another CentOS 5 box.
I did changes through administration/installation and test db was OK, instead, all was ok.
But now after restart both linux boxes, zabbix_server.log output is:
Error is pretty clear. Cann connect with MySQL server. But how can it be? I did the steps with Administration/installation and I change IP of MySQL server. And test connections worked good!
I have checked conf/zabbix.conf.php and the changes that I did before are in the file. So this ok too.
What's happening?
I know most of people using zabbix can separate MySQL from Zabbix Server Web...
8091:20100923:143509 Starting zabbix_server. ZABBIX 1.6.5 (revision 7442). 8091:20100923:143509 **** Enabled features **** 8091:20100923:143509 SNMP monitoring: NO 8091:20100923:143509 WEB monitoring: YES 8091:20100923:143509 Jabber notifications: NO 8091:20100923:143509 ODBC: NO 8091:20100923:143509 IPv6 support: NO 8091:20100923:143509 ************************** 8091:20100923:143509 [Z3001] Connection to database 'zabbix' failed: [2002] Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
What's happening?
