If you're looking for your trend data which is older than 5 months you will do something like the following: (mysql)
select * from trends where clock<UNIXTIME((now() - INTERVAL 5 MONTHS)); That
will should pull all data from the trends table which is older than 5 months. There is a second trends table trends_uint. The history tables should only contain data up to the time set in the item's configuration history retention time.
The trends table as the name suggests keeps only the trends(hourly averages of your gathered data).
To easily find the largest tables why don't you try accessing the DB using a GUI tool like HeidiSQL or MySQL-Admin?
Anyways,
the largest ones will be history, history_uint and events.
Remember you shouldn't mess with the DB without being sure what you're doing.
You can also tweak how long Zabbix will keep each items data when creating/configuring them typing your intended
'Keep history (in days)' and
'Keep trends (in days)'
