Active check failed
  • reaper
    • Oct 2010
    • 9
    Active check failed
    I've tried to use template offered at this topic http://www.zabbix.com/forum/showthread.php?t=8847
    After I've set things up values do not appear in zabbix. In zabbix_server.log I see following errors:
     20319:20101011:064911.598 Process data failed: Connection from [::ffff:192.168.176.43] rejected. Allowed server is [localhost]
     20319:20101011:064912.047 Process data failed: Connection from [::ffff:192.168.176.43] rejected. Allowed server is [localhost]
     20319:20101011:064912.493 Process data failed: Connection from [::ffff:192.168.176.43] rejected. Allowed server is [localhost]
     20320:20101011:064937.162 Process data failed: Connection from [::ffff:192.168.176.43] rejected. Allowed server is [localhost]
     20318:20101011:064937.607 Process data failed: Connection from [::ffff:192.168.176.43] rejected. Allowed server is [localhost]
    The only localhost in zabbix_server.conf is DBHost
    Also I've found such errors applying for zabbix_agent but not zabbix_server. Zabbix version is 1.8.2 from Debian backports.
  • reaper
    • Oct 2010
    • 9
    found another localhosts )
    in every item of that template, now it's ok
