Can't figure out "Not all Templates are linked to host"
  • arli
    • Jan 2008
    • 71
    I have a lot of templates. Some of them are created from scratch and some are created using full cloning feature.
    Today I discovered, that I cannot save many of them.
    When going into Configuration > Templates > choose one > Triggers > edit the trigger and hit Save button, it gives me this error:
    Not all Templates are linked to host [ ant01.mydomain.com ]
    I suspected that there was some mixup with this host and deleted it and retried again, but then there was error about ant02... so I guess, it is complaining about that host just because it is alfabetically the first one.
    I haven't changed my templates recently so it has to be control mechanism created in some new Zabbix version, that is kicking in now.
    I looked up from the triggers.inc.php file and there is this function
    // Deny adding dependency between templates ifthey are not high level templates
    	function validate_trigger_dependency($expression, $deps)
    I have a template that includes checks that host is up and zabbix agent is running. And inside this template, agent trigger A is depending on the host trigger B.
    All the other triggers on the other templates are depending on either trigger A (agent related checks: cpu, disk etc.) or trigger B (agentless checks: ports, web).
    So what does this "high level template" mean? I thought all templates were on the same level.
    It seems to me that dependencies between templates are forbidden now. Go figure it out.
  • arli
    • Jan 2008
    • 71
    Hi Zabbix developers, can you please explain this or confirm a bug so I could fill a report in tracker.
    At the moment I'm very confused about this kind of behaviour and I hope I don't have to redesign my templates system
    • DSon
      • Sep 2009
      • 44
      I've got exactly the same problem..
      Appears to have started happening since upgrading from Zabbix 1.8.1 to 1.8.3, after which I imported some Templates.
      Now when trying to ammend any Trigger containing dependencies, I get "Not all Templates are linked to host <NNNN>..".
      I've tried looking for circular references but not found any. All these templates were working with dependencies before the upgrade.
      Is the latest stable version of Zabbix broke?
      Please help,
      Danny.
      • DSon
        • Sep 2009
        • 44
        Here is what is wrong...
        I'm not a programmer.. but it seems the code Zabbix is now using for checking trigger dependencies within linked templates is definitely broke.
        Here's a simplified example of what is happening:
        - Template (1) is linked to both HOST (A) and HOST (B)
        - Template (2) is only linked to HOST (A)
        - I attempt to update a Trigger in Template (2) which contains a dependency to a Trigger in Template (1)
        - ERROR: "Not all Templates are linked to host [ HOST (B) ]"
        - I then link Template (2) to HOST (B) as well as HOST (A)
        - I attempt to update the Trigger in Template (2)
        - WORKS!
        How does one go about reporting bugs?
        Danny.
        • Andreas Bollhalder
          • Apr 2007
          • 144
          Same with 2.0.4
          Has this only be resolved in 1.8.4 and later ?
          I get the message in 2.0.4 if I make a dependency of a trigger to a trigger of another template.
          Any news ?
          Thanks in advance.
          Andreas
          Zabbix statistics
          Total hosts: 380 - Total items: 12190 - Total triggers: 4530 - Required server performance: 224.2
          • jairoalves
            • Jan 2015
            • 15
            Can anyone confirm this problem still exists? I'm on 2.0.3.
