Agents behind a proxy are shown as "unreachable" ('status' parameter not works)
  • parcival
    • Sep 2010
    • 44
    Hi all (and privjet eastward),
    i have exactly the same problem, as described here.
    I use the most current zabbix version. Does it give an bugfix for it ?
    What would the best alternative for "status.last(0)}=2" ?
    - status.last(0)=2 does not work through a proxy
    - agent.ping.nodata(120)=1 is artificially delayed (although the proxy/server knows that the agent is unreachable)
    - icmpping.last(0)=1 would detect whether the system is down (possible workaround)
    - tcp,port[10050].last(0)=1 would detect whether the agent is listening (possible workaround)
    Thanks for each assistance.
    parcival
