I am having this troubleshoot, which is most common troubleshoot.
I think its a simple fix but i am unable to find a solution to it.
My GUI shows that zabbix agent is not supported whenever i try to activate an Item.
The error log file of agent on the zabbix server says
zabbix_agentd [29108]: ERROR: File [/tmp/zabbix_agentd.pid] exists and is locked. Is this process already running ?
I don't know what the problem would be. The error log file on zabbix remote agent is empty.
I was able to establish a connection to telnet, and the local host configuration and the hostname are matching.
I am suspecting that it could be a simple fix which i am unable to identify.
Error on server log
7744:20101018:125417.326 Send list of active checks to [10.10.10.10] failed: host [10.10.10.11/zabbix] not found
7741:20101018:125431.818 Item [eve2 Client:system.cpu.load[<cpu> <,mode>]] error: Not supported by Zabbix Agent
Any help is appreciated.
Error on server log
