Server is randomly down since Beta5
  • llopht
    • May 2005
    • 19
    Since the Beta 5 my zabbix server is randomly down (I use the Beta 4 zabbix_server process) . I have try to compile the beta5 binaries but I have always this message withe the make process :
    make[4]: Nothing to do for « all-am ».
    make[4]: Leaving directory `/root/zabbix-1.1beta5/src/zabbix_server/trapper'
    make[3]: Leaving directory `/root/zabbix-1.1beta5/src/zabbix_server/trapper'
    make[3]: Entering directory `/root/zabbix-1.1beta5/src/zabbix_server'
    make[3]: Nothing to do for « all-am ».
    make[3]: Leaving directory `/root/zabbix-1.1beta5/src/zabbix_server'
    make[2]: Leaving directory `/root/zabbix-1.1beta5/src/zabbix_server'
    make[2]: Entering directory `/root/zabbix-1.1beta5/src'
    make[2]: Nothing to do for « all-am ».
    Why ? No matter with the configure...
    Jérôme
  • aimon
    • Jan 2006
    • 9
    Similar issue
    I to am having this compile problem. I am compiling beta5 on a Debian system with MySQL 4.1. basically trapper doesn't compile and when i try to run the server it just hangs.
    using:
    ./configure --enable-server --enable-agent --with-mysql
    please see attached outputs
    • cameronsto
      • Oct 2005
      • 148
      I get this as well on my FC4 box. I get the same make messages about 'nothing to do' but it does create a zabbix_server bin. When I run that it just exits immediately. Not sure what's going on. Seems to work fine on my Centos 4.2 box.
      -cameron
