deleted host still sending active checks
  • acalvo
    • Oct 2010
    • 30
    After deleting a host, zabbix server still tries to send the list of active checks to that host.
    What I've done:
    Created a host
    Assigned a template
    Confirm it was working
    Disable host
    Unlink and clear templates
    Delete host
    This is the output from zabbix_server.log:
    22218:20101105:131242.964 Sending list of active checks to [192.168.0.82] failed: host [AS5] not found
  • Zaniwoop
    • Jan 2010
    • 232
    If you query the database, is it still there?
    USE zabbix;
    SELECT host FROM hosts where ip = '192.168.0.82';
    • acalvo
      • Oct 2010
      • 30
      USE zabbix;
      It doesn't exist:
      mysql> SELECT host FROM hosts where ip = '192.168.0.82';
      Empty set (0.00 sec)
      • alixen
        • Apr 2006
        • 474
        What you get is normal.
        Zabbix agent asks periodically Zabbix server about active checks.
        If you have deleted that host in Zabbix server, Zabbix server logs an error message because it doesn't know this client anymore.
        If don't want to see this error message, just stop zabbix agent on client host.
        Regards,
        Alixen
        http://www.alixen.fr/zabbix.html
        • acalvo
          • Oct 2010
          • 30
          Regards,
          Alixen
          You're right.
          I've thought it was the server who was trying to contact the agent (which I supposed it was already stopped).
          • bashman
            • Dec 2009
            • 432
            You can also add "DisableActive=1" to zabbix_agentd.conf.
            978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15
