UserParameter problem (nothing in lastest data)
  • Flexyz
    • Oct 2010
    • 30
    Hi
    I have a few user defined parameters but when the remote command takes more than about 4.8secs nothing is reported back to "latest data" - even though log on agent is writing "sending back [xx]" at all times
    I also tried a simpel vbs script that returns a value and sleeps x secs - and it all works when < 4.8 secs of sleep
  • richlv
    • Oct 2005
    • 3112
    should be 3 seconds, actually - see the timeout option in both agent and server config files. and it's not really suggested to increase that much - better work on speeding up your userparameter
    • Flexyz
      • Oct 2010
      • 30
      Timeout on agent is set to 30
      • richlv
        • Oct 2005
        • 3112
        but you didn't say anything about server timeout. and again, that's a bad idea (30 sec timeout)
        • Flexyz
          • Oct 2010
          • 30
          thanks will try the server timeout
          • Flexyz
            • Oct 2010
            • 30
            Thanks that worked
