How can i make external intranet page embedding from ZABBIX map
  • kapix
    • Nov 2010
    Hi Experts !
    I would like to get help from you about a simple, but even so complicated subject! So, how can i embedding a dynamic NetWork Map page from ZABBIX to a Share Point based intranet page using the "page viewer" - WebPart. How can i solve the authentication problems from Zabbix to Public access.
    Please take advice i you can.
    Thanks advance: Gyorgy Kaplan
  • brian
    • Dec 2009
    • 45
    I am also interested in this...
    ::Bence
    • alixen
      • Apr 2006
      • 474
      You can set "Guests" user group access rights to "read only" for all hosts contained in your map.
      In this case, no authentication is needed to display the map.
      Regards,
      Alixen
      http://www.alixen.fr/zabbix.html
      • kapix
        • Nov 2010
        Thanks ! It works
        Dear Alixen !
        Your advice was great ! After i've set the parameters this map page works properly on another web page.
        Regards,
        Alixen
