Zabbix 1.8.3 API & trigger addDependencies
  • to6ko
    • Jun 2007
    trying to add trigger dependencies
    ZabbixAPI::query('trigger','addDependencies', array(triggerid=>"100100000013986", dependsOnTriggerid=>"100100000023172"))
    or die('Unable to update: '.print_r(ZabbixAPI::getLastError(),true));
    echo "triger updated\n";
    the output:
    [code] => -32602
    [message] => Invalid params.
    [data] => [ CTrigger::addDependencies ] Cannot create dependency
    the postgre database shows the error :
    STATEMENT: INSERT INTO trigger_depends (triggerdepid,triggerid_down,triggerid_up) VALUES (100100000010640,100100000013986,)
    ERROR: syntax error at or near ")" at character 113
    Any suggestions ?
  • nelsonab
    • Sep 2006
    • 1233
    I suggest you submit a bug
    RHCE, author of zbxapi
    • to6ko
      • Jun 2007
      resolved!
      I just found out that is working in pre-zabbix-1.8.4rc2.x-15360
