Unix Millenium Bug
  • vijaya.r85
    • Apr 2009
    • 20
    Unix Millenium Bug
    I am facing date issue in a customized report in zabbix 1.8.3 version. On selecting the filters for current day and submitting, it automatically turns for 19th January 2038. On surfing I found this as Unix Millennium bug. Please help to resolve this.
    Thanks in advance.
    Regards,
    Vijaya
  • nelsonab
    • Sep 2006
    • 1233
    More information is required about this problem Yes there is a known issue with time in the standard C library which most Unix derivatives are built upon and that is once you get 2^32 seconds from Jan 1, 1970 time rolls over.
    As for your specific issue more information is needed. I'm sorry but we all suck at mind reading here. :-)
    RHCE, author of zbxapi
    • vijaya.r85
      • Apr 2009
      • 20
      Unix Millenium Bug
      Thanks for your reply Mr. Nelsonab. I have written a script (Groupreport.php) to generate a consolidated report for the group of devices configured and added it in the Report menu of Zabbix. User when selects the dates and clicks filter the report will be generated for the specific dates. This is working fine in zabbix 1.6.4 version for the past 1.5 years. Same I have implemented in zabbix 1.8.3 version. Till a month before it was working fine in this version. Now when I select the dates and click filter, it is generating me the output of January 19 2038. When I call the same script through command line with perl LWP::Agent it works perfect and generates the report aptly. Am quite confused.
      Please Help.
      • nelsonab
        • Sep 2006
        • 1233
        I don't know how to help. One thing you could do is make use of a good php debugger. Jetbrains has a good IDE which integrates with the xdebug module for php and is very affordable. I use that program when I'm doing any work on the Zabbix php code.
        Otherwise with the information given it's going to be difficult for anyone to help. The only thing that sticks out in my head is an environment issue, perhaps you're using a global variable which is being overwritten by the Zabbix code, but like I said it's very difficult for anyone to know with the information given.
        • vijaya.r85
          • Apr 2009
          • 20
          Unix Millenium Bug
          Thanks for your reply nelsonab. I will check
          Regards,
          Vijaya
