Zabbix 1.8.3 / 1.8.2 massive deadlock problems
  • f.koch
    • Feb 2010
    • 85
    Hi @all,
    we have massive problems in our productive monitoring.
    we have upgraded from 1.8.2 to 1.8.3 on 17.11.10 , since 26.11.10 there are massive deadlock errors in the zabbix log, and in the DB (mysql).
    Since the deadlocks appear the server works some time well and then with each deadlock the load go higher and higher. At some point the server stops working.
    I have downgraded to zabbix 1.8.2 , the deadlock isn't completly gone but comes with much lower frequency, and the server works "well" (works, but i don't know how long)
    Innodb Status:
    101127 16:55:36 INNODB MONITOR OUTPUT
    Per second averages calculated from the last 9 seconds
    SEMAPHORES
    OS WAIT ARRAY INFO: reservation count 2141678, signal count 2045441
    Mutex spin waits 0, rounds 772411483, OS waits 1191620
    RW-shared spins 1061752, OS waits 253238; RW-excl spins 3791177, OS waits 95304
    LATEST DETECTED DEADLOCK
    101127 16:52:55
    *** (1) TRANSACTION:
    TRANSACTION 0 1309159616, ACTIVE 0 sec, process no 9212, OS thread id 1101355328 starting index read
    mysql tables in use 1, locked 1
    LOCK WAIT 2 lock struct(s), heap size 368
    MySQL thread id 38, query id 46589957 localhost zabbix updating
    delete from escalations where escalationid=7712544
    *** (1) WAITING FOR THIS LOCK TO BE GRANTED:
    RECORD LOCKS space id 14 page no 57 n bits 264 index `PRIMARY` of table `zabbix/escalations` trx id 0 1309159616 lock_mode X locks rec but not gap waiting
    Record lock, heap no 188 PHYSICAL RECORD: n_fields 10; compact format; info bits 32
     0: len 8; hex 000000000075af20; asc      u  ;; 1: len 6; hex 00004e0830b6; asc   N 0 ;; 2: len 7; hex 0000002b5704b1; asc    +W  ;; 3: len 8; hex 000000000000000d; asc         ;; 4: len 8; hex 0000000000000000; asc         ;; 5: len 8; hex 0000000000af9ad0; asc         ;; 6: len 8; hex 0000000000000000; asc         ;; 7: len 4; hex 80000000; asc     ;; 8: len 4; hex 80000000; asc     ;; 9: len 4; hex 80000000; asc     ;;
    *** (2) TRANSACTION:
    TRANSACTION 0 1309159606, ACTIVE 0 sec, process no 9212, OS thread id 1176361280 fetching rows, thread declared inside InnoDB 170
    26 lock struct(s), heap size 6752, undo log entries 5
    MySQL thread id 7, query id 46590056 localhost zabbix updating
    delete from escalations where actionid=64 and triggerid=0
    *** (2) HOLDS THE LOCK(S):
    RECORD LOCKS space id 14 page no 57 n bits 256 index `PRIMARY` of table `zabbix/escalations` trx id 0 1309159606 lock_mode X locks rec but not gap
    *** (2) WAITING FOR THIS LOCK TO BE GRANTED:
    RECORD LOCKS space id 14 page no 57 n bits 264 index `PRIMARY` of table `zabbix/escalations` trx id 0 1309159606 lock_mode X waiting
    *** WE ROLL BACK TRANSACTION (1)
    TRANSACTIONS
    Trx id counter 0 1309167592
    Purge done for trx's n:o < 0 1309162234 undo n:o < 0 0
    History list length 921
    Total number of lock structs in row lock hash table 0
    LIST OF TRANSACTIONS FOR EACH SESSION:
    ---TRANSACTION 0 0, not started, process no 9212, OS thread id 1101621568
    MySQL thread id 18405, query id 46703780 localhost root
    SHOW ENGINE INNODB STATUS
    ---TRANSACTION 0 1309162239, not started, process no 9212, OS thread id 1184614720
    MySQL thread id 43, query id 46624922 localhost zabbix
    ---TRANSACTION 0 1309166313, not started, process no 9212, OS thread id 1184082240
    MySQL thread id 41, query id 46682100 localhost zabbix
    ---TRANSACTION 0 1309163262, not started, process no 9212, OS thread id 1184348480
    MySQL thread id 42, query id 46640462 localhost zabbix
    ---TRANSACTION 0 1309166295, not started, process no 9212, OS thread id 1184880960
    MySQL thread id 44, query id 46681911 localhost zabbix
    ---TRANSACTION 0 1309155236, not started, process no 9212, OS thread id 1183017280
    MySQL thread id 32, query id 46697449 localhost zabbix
    ---TRANSACTION 0 1309166479, not started, process no 9212, OS thread id 1183816000
    MySQL thread id 40, query id 46685672 localhost zabbix
    ---TRANSACTION 0 1309167518, not started, process no 9212, OS thread id 1101089088
    MySQL thread id 37, query id 46702000 localhost zabbix
    ---TRANSACTION 0 1309167577, not started, process no 9212, OS thread id 1101355328
    MySQL thread id 38, query id 46703766 localhost zabbix
    ---TRANSACTION 0 1309167581, not started, process no 9212, OS thread id 1182218560
    MySQL thread id 29, query id 46703770 localhost zabbix
    ---TRANSACTION 0 1309167446, not started, process no 9212, OS thread id 1176361280
    MySQL thread id 7, query id 46700688 localhost zabbix
    ---TRANSACTION 0 1309167579, not started, process no 9212, OS thread id 1185147200
    MySQL thread id 45, query id 46703768 localhost zabbix
    ---TRANSACTION 0 1309167536, not started, process no 9212, OS thread id 1180887360
    MySQL thread id 24, query id 46702361 localhost zabbix
    ---TRANSACTION 0 1309167534, not started, process no 9212, OS thread id 1100822848
    MySQL thread id 36, query id 46702359 localhost zabbix
    ---TRANSACTION 0 1309167511, not started, process no 9212, OS thread id 1181952320
    MySQL thread id 28, query id 46701553 localhost zabbix
    ---TRANSACTION 0 1309167031, not started, process no 9212, OS thread id 1176095040
    MySQL thread id 6, query id 46696264 localhost zabbix
    ---TRANSACTION 0 1309167529, not started, process no 9212, OS thread id 1181419840
    MySQL thread id 26, query id 46702181 localhost zabbix
    ---TRANSACTION 0 1309167080, not started, process no 9212, OS thread id 1180621120
    MySQL thread id 23, query id 46697453 localhost zabbix
    ---TRANSACTION 0 1309167372, not started, process no 9212, OS thread id 1182484800
    MySQL thread id 30, query id 46699977 localhost zabbix
    ---TRANSACTION 0 1309167590, not started, process no 9212, OS thread id 1183549760
    MySQL thread id 34, query id 46703779 localhost zabbix
    ---TRANSACTION 0 1309167558, not started, process no 9212, OS thread id 1181153600
    MySQL thread id 25, query id 46703522 localhost zabbix
    ---TRANSACTION 0 1309167544, not started, process no 9212, OS thread id 1181686080
    MySQL thread id 27, query id 46702889 localhost zabbix
    ---TRANSACTION 0 1309167033, not started, process no 9212, OS thread id 1176627520
    MySQL thread id 8, query id 46696265 localhost zabbix
    ---TRANSACTION 0 1309167487, not started, process no 9212, OS thread id 1180088640
    MySQL thread id 21, query id 46700830 localhost zabbix
    ---TRANSACTION 0 1308633682, not started, process no 9212, OS thread id 1179556160
    MySQL thread id 19, query id 46688063 localhost zabbix
    ---TRANSACTION 0 1309167491, not started, process no 9212, OS thread id 1100036416
    MySQL thread id 4, query id 46701494 localhost zabbix
    ---TRANSACTION 0 1309167563, not started, process no 9212, OS thread id 1100302656
    MySQL thread id 5, query id 46703744 localhost zabbix
    ---TRANSACTION 0 1309166242, not started, process no 9212, OS thread id 1099770176
    MySQL thread id 3, query id 46680958 localhost zabbix
    ---TRANSACTION 0 1309162230, ACTIVE 109 sec, process no 9212, OS thread id 1075734848, thread declared inside InnoDB 51
    mysql tables in use 1, locked 0
    MySQL thread id 35, query id 46624910 localhost zabbix Sending data
    select count(*) from history
    Trx read view will not see trx with id >= 0 1309162231, sees < 0 1309162231
    FILE I/O
    I/O thread 0 state: waiting for i/o request (insert buffer thread)
    I/O thread 1 state: waiting for i/o request (log thread)
    I/O thread 2 state: waiting for i/o request (read thread)
    I/O thread 3 state: waiting for i/o request (write thread)
    Pending normal aio reads: 0, aio writes: 0,
     ibuf aio reads: 0, log i/o's: 0, sync i/o's: 0
    Pending flushes (fsync) log: 0; buffer pool: 0
    2732724 OS file reads, 1353767 OS file writes, 103404 OS fsyncs
    0.00 reads/s, 0 avg bytes/read, 18.11 writes/s, 1.44 fsyncs/s
    INSERT BUFFER AND ADAPTIVE HASH INDEX
    Ibuf: size 1, free list len 858, seg size 860,
    43843 inserts, 43843 merged recs, 6749 merges
    Hash table size 53124517, used cells 37607794, node heap has 96409 buffer(s)
    28148.43 hash searches/s, 3621.49 non-hash searches/s
    LOG
    Log sequence number 174 3599694510
    Log flushed up to   174 3599687481
    Last checkpoint at  174 3016664921
    1 pending log writes, 0 pending chkp writes
    920882 log i/o's done, 8.11 log i/o's/second
    BUFFER POOL AND MEMORY
    Total memory allocated 29690863256; in additional pool allocated 1048576
    Buffer pool size   1638400
    Free buffers       148
    Database pages     1541843
    Modified db pages  105853
    Pending reads 0
    Pending writes: LRU 0, flush list 0, single page 0
    Pages read 7979978, created 72377, written 734627
    0.00 reads/s, 0.89 creates/s, 15.22 writes/s
    Buffer pool hit rate 1000 / 1000
    ROW OPERATIONS
    1 queries inside InnoDB, 0 queries in queue
    2 read views open inside InnoDB
    Main thread process no. 9212, id 1175828800, state: flushing log
    Number of rows inserted 8256122, updated 8520531, deleted 10025415, read 44545542888
    148.09 inserts/s, 152.09 updates/s, 5.22 deletes/s, 1172040.55 reads/s
    END OF INNODB MONITOR OUTPUT
    Zabbix server log:
     7048:20101126:141112.192 [Z3005] Query failed: [1213] Deadlock found when trying to get lock; try restarting transaction [update escalations set status=4 where actionid=64 and triggerid=0 and esc_step=0 and status=0]
      7126:20101126:141112.198 [Z3005] Query failed: [1213] Deadlock found when trying to get lock; try restarting transaction [delete from escalations where escalationid=7378780 and status=4]
      7048:20101126:141112.270 [Z3005] Query failed: [1213] Deadlock found when trying to get lock; try restarting transaction [update escalations set status=4 where actionid=64 and triggerid=0 and esc_step=0 and status=0]
      7048:20101126:141112.310 [Z3005] Query failed: [1213] Deadlock found when trying to get lock; try restarting transaction [update escalations set status=4 where actionid=64 and triggerid=0 and esc_step=0 and status=0]
    mysqld config
    [mysqld]
    skip-bdb
    tmpdir=/var/tmp/mysqltmp
    datadir=/var/lib/mysql
    socket=/var/lib/mysql/mysql.sock
    user=mysql
    innodb_file_per_table=1
    innodb_flush_method=O_DIRECT
    innodb_log_file_size=512M
    innodb_log_buffer_size=4M
    innodb_buffer_pool_size=25G
    innodb_thread_concurrency=8
    query_cache_limit=1M
    query_cache_size=512M
    tmp_table_size=256M
    max_heap_table_size=256M
    max_connections = 400
    innodb_flush_log_at_trx_commit=2
    join_buffer_size=2048K
    read_buffer_size=256k
    read_rnd_buffer_size=256k
    thread_cache_size=4
    table_cache=102
    Server
    4x Intel(R) Xeon(TM) MP CPU 3.16GHz
    32 GB Ram
    os: Centos5
    More Infos needed?
    rgds flo
  • f.koch
    • Feb 2010
    • 85
    I have fixed this, i have reniced the mysqld process from 0 to -10. Now it works. No more deadlocks.
    rgds Flo
