Hello all.
I installed zabbix 1.8 on CentOS5.4.
ZABBIX Server's status is available but agent status is not available with the following error:
"Got empty string from [xxx.xxx.xxx.128]. Assuming that agent dropped connection because of access permissions"
xxx.xxx.xxx.128 is my zabbix server&agent address.
I can reached 10050&10051 port on this server by telnet.
/etc/zabbix/zabbix_agentd.conf
Server=xxx.xxx.xxx.128
ServerPort=10050
Hostname=xxx.xxx.xxx.128
#ListenPort=10050
#ListenIP=xxx.xxx.xxx.128
/etc/zabbix/zabbix_server.conf
2nd problem is with other monitored server.
Error message is "Get value from agent failed: Cannot resolve"
ZABBIX server(xxx.xxx.xxx.128) is the same as above.
Host server(installed zabbix agent) is xxx.xxx.xxx.129.
ListenPort=10060
ListenIP=xxx.xxx.xxx.129
This host server has an item for icmpping by simple check.
How can i monitor the agents??
Firewall and selinux are disabled.
Thank you.
ServerPort=10050
#ListenPort=10050
ListenPort=10060
Thank you.
