make install issues
  • Davidus
    • Dec 2010
    • 281
    make install issues
    Hello everyone
    I have successfully ./configure Zabbix, however, when I`m doing “make install” I`m facing following errors:
    serv1:/usr/local/zabbix-1.8.3#make install
    Making install in src
    Making install in libs
    Making install in zbxcrypto
    gcc -DHAVE_CONFIG_H -I. -I../../../include -g -O2 -I'/usr/include/mysql' -I/usr/src/iksemel-1.3/include -I/opt/freeware/include -I/usr/local/include -I. -I/opt/freeware/include -MT md5.o -MD -MP -MF .deps/md5.Tpo -c -o md5.o md5.c
    In file included from /usr/include/xcoff.h:134,
    from /usr/include/a.out.h:42,
    from /usr/include/sys/user.h:54,
    from ../../../include/sysinc.h:301,
    from ../../../include/common.h:23,
    from md5.c:54:
    /usr/include/mysql/dbug.h:38: error: expected '=', ',', ';', 'asm' or '__attribute__' before '_VARARGS'
    make: 1254-004 The error code from the last command is 1.
    Stop.
    Stop.
    Stop.
    Stop.
    Can anybody help me solve this problem?
  • richlv
    • Oct 2005
    • 3112
    looks like plain compilation fails on /usr/include/mysql/dbug.h
    which os/distribution ? can you try reinstalling mysql development headers ?
    • Davidus
      • Dec 2010
      • 281
      I`m using AIX 5.3 unfortunately
      I can reinstall everything if necessary, cause I just wanna make it work…
      Let me explain what I did; actually, I think that this was inappropriate move
      I got MySQL from MySQL official web-site, when I was doing ./configure part it asked me mysql client, devel and stuff, because I wasn’t able to get all this stuff anywhere I got RPMs and it looked like everything is going to work, now I think that this wasn’t good idea now I faced this issue and think like I have to start everything again…
      I`m going to try reinstall SQL stuff and will let you know what is going to happened
      Thank you for respond
      • Davidus
        • Dec 2010
        • 281
        I tried, however, it didn`t worked out... I even tried different rpm-s for client and devel...and keep getting same error on make install
        • Davidus
          • Dec 2010
          • 281
          I edited dbug.h file
          extern void _db_doprnt_ _VARARGS((const char *format,...));
          to
          extern void _db_doprnt_VARARGS(const char *format);
          and os some point problem is solved
          however, now I have following error:
          Making install in zbxdb
          gcc -DHAVE_CONFIG_H -I. -I../../../include -g -O2 -I'/usr/include/mysql' -I/usr/src/iksemel-1.3/include -I/opt/freeware/include -I/usr/local/include -I. -I/opt/freeware/include -MT db.o -MD -MP -MF .deps/db.Tpo -c -o db.o db.c
          db.c: In function 'zbx_db_connect':
          db.c:139: error: 'CLIENT_MULTI_STATEMENTS' undeclared (first use in this function)
          db.c:139: error: (Each undeclared identifier is reported only once
          db.c:139: error: for each function it appears in.)
          Stop.
          Stop.
          Stop.
          Stop.
          • dave_t
            • Apr 2007
            • 28
            I have a similar - possibly related problem to compile error on AIX
            Fist of all, I have to say that Zabbix really is an excellent product, and I've been running it: compiled with with jabber/curl/netsnmp etc - basically everything on Fedora on PPC since version 1.4.2.
            However, I really need to move off the fedora installation onto AIX.
            I had similar "make" errors as reported by "Davidus", with both the GNU Make 3.80 and the AIX version of make on AIX6.1
            Therefore I gave up and reverted back to a vanilla AIX5300-09 installation.
            However, after installing mysql from mysql.com (version mysql-5.1.53-aix5.3-powerpc-64bit.tar.gz)
            the output of configure:
            # ./configure --enable-server --with-mysql
            checking for mysql_config... /usr/local/mysql/bin/mysql_config
            checking for main in -lmysqlclient ... no
            configure: error: Not found mysqlclient library
            # echo $LDFLAGS
            -L/zabbix_db_fs/mysql-5.1.53-aix5.3-powerpc-64bit/lib -lmysqlclient
            # /usr/local/mysql/bin/mysql_config
            Usage: /usr/local/mysql/bin/mysql_config [OPTIONS]
            Options:
            --cflags [-I/usr/local/mysql/include -g -q64 -ma -qstrict -qoptimize=2 -qmaxmem=8192 -DUNIV_AIX -DUNIV_AIX]
            --include [-I/usr/local/mysql/include]
            --libs [-Wl,-brtl -L/usr/local/mysql/lib -lmysqlclient -lz -lnsl_r -lm]
            --libs_r [-Wl,-brtl -L/usr/local/mysql/lib -lmysqlclient_r -lz -lnsl_r -lm]
            --plugindir [/usr/local/mysql/lib/plugin]
            --socket [/tmp/mysql.sock]
            --port [0]
            --version [5.1.53]
            --libmysqld-libs [-Wl,-brtl -L/usr/local/mysql/lib -lmysqld -ldl -lz -lnsl_r -lm -lrt]
            # ls -l /usr/local/mysql/include /usr/local/mysql/lib
            /usr/local/mysql/include:
            total 888
            -rw-r--r-- 1 root mysql 4058 Nov 5 19:22 decimal.h
            -rw-r--r-- 1 root mysql 3854 Nov 5 19:22 errmsg.h
            -rw-r--r-- 1 root mysql 6954 Nov 5 19:22 keycache.h
            -rw-r--r-- 1 root mysql 22690 Nov 5 19:22 m_ctype.h
            -rw-r--r-- 1 root mysql 7451 Nov 5 19:22 m_string.h
            -rw-r--r-- 1 root mysql 1804 Nov 5 19:22 my_alloc.h
            -rw-r--r-- 1 root mysql 1941 Nov 5 19:22 my_attribute.h
            -rw-r--r-- 1 root mysql 3991 Nov 5 19:22 my_compiler.h
            -rw-r--r-- 1 root mysql 37039 Nov 5 19:22 my_config.h
            -rw-r--r-- 1 root mysql 6947 Nov 5 19:22 my_dbug.h
            -rw-r--r-- 1 root mysql 3460 Nov 5 19:22 my_dir.h
            -rw-r--r-- 1 root mysql 3669 Nov 5 19:22 my_getopt.h
            -rw-r--r-- 1 root mysql 52661 Nov 5 19:22 my_global.h
            -rw-r--r-- 1 root mysql 1488 Nov 5 19:22 my_list.h
            -rw-r--r-- 1 root mysql 3656 Nov 5 19:22 my_net.h
            -rw-r--r-- 1 root mysql 1763 Nov 5 19:22 my_no_pthread.h
            -rw-r--r-- 1 root mysql 27068 Nov 5 19:22 my_pthread.h
            -rw-r--r-- 1 root mysql 41391 Nov 5 19:22 my_sys.h
            -rw-r--r-- 1 root mysql 2677 Nov 5 19:22 my_xml.h
            -rw-r--r-- 1 root mysql 33724 Nov 5 19:22 mysql.h
            -rw-r--r-- 1 root mysql 20494 Nov 5 19:22 mysql_com.h
            -rw-r--r-- 1 root mysql 1130 Nov 5 19:22 mysql_embed.h
            -rw-r--r-- 1 root mysql 2097 Nov 5 19:22 mysql_time.h
            -rw-r--r-- 1 root mysql 820 Nov 5 19:22 mysql_version.h
            -rw-r--r-- 1 root mysql 23447 Nov 5 19:22 mysqld_ername.h
            -rw-r--r-- 1 root mysql 23502 Nov 5 19:22 mysqld_error.h
            -rw-r--r-- 1 root mysql 29654 Nov 5 19:22 plugin.h
            -rw-r--r-- 1 root mysql 1957 Nov 5 19:22 sql_common.h
            -rw-r--r-- 1 root mysql 12332 Nov 5 19:22 sql_state.h
            -rw-r--r-- 1 root mysql 1006 Nov 5 19:22 sslopt-case.h
            -rw-r--r-- 1 root mysql 2061 Nov 5 19:22 sslopt-longopts.h
            -rw-r--r-- 1 root mysql 1107 Nov 5 19:22 sslopt-vars.h
            -rw-r--r-- 1 root mysql 1501 Nov 5 19:22 typelib.h
            /usr/local/mysql/lib:
            total 147328
            -rw-r--r-- 1 root mysql 6001 Nov 5 19:22 libdbug.a
            -rw-r--r-- 1 root mysql 772598 Nov 5 19:22 libheap.a
            -rw-r--r-- 1 root mysql 2783065 Nov 5 19:22 libmyisam.a
            -rw-r--r-- 1 root mysql 973469 Nov 5 19:22 libmyisammrg.a
            -rw-r--r-- 1 root mysql 3485051 Nov 5 19:22 libmysqlclient.a
            -rwxr-xr-x 1 root mysql 994 Nov 5 19:22 libmysqlclient.la
            lrwxrwxrwx 1 503 staff 24 Dec 11 22:24 libmysqlclient.so -> libmysqlclient.so.16.0.0
            lrwxrwxrwx 1 503 staff 24 Dec 11 22:24 libmysqlclient.so.16 -> libmysqlclient.so.16.0.0
            -rwxr-xr-x 1 root mysql 3157127 Nov 5 19:22 libmysqlclient.so.16.0.0
            -rw-r--r-- 1 root mysql 3546337 Nov 5 19:22 libmysqlclient_r.a
            -rwxr-xr-x 1 root mysql 1008 Nov 5 19:22 libmysqlclient_r.la
            lrwxrwxrwx 1 503 staff 26 Dec 11 22:24 libmysqlclient_r.so -> libmysqlclient_r.so.16.0.0
            lrwxrwxrwx 1 503 staff 26 Dec 11 22:24 libmysqlclient_r.so.16 -> libmysqlclient_r.so.16.0.0
            -rwxr-xr-x 1 root mysql 3223680 Nov 5 19:22 libmysqlclient_r.so.16.0.0
            -rw-r--r-- 1 root mysql 53646387 Nov 5 19:23 libmysqld.a
            -rw-r--r-- 1 root mysql 2119775 Nov 5 19:22 libmystrings.a
            -rw-r--r-- 1 root mysql 1355704 Nov 5 19:22 libmysys.a
            -rw-r--r-- 1 root mysql 40900 Nov 5 19:23 libvio.a
            -rw-r--r-- 1 root mysql 279330 Nov 5 19:22 libz.a
            -rwxr-xr-x 1 root mysql 876 Nov 5 19:22 libz.la
            drwxr-xr-x 2 root mysql 4096 Dec 11 22:38 plugin
            Anyone got any ideas, as this has taken a couple of days (well a few hours) of my life
            • Davidus
              • Dec 2010
              • 281
              dave_t
              I solved this problem installing mysql-client and mysql-devel rpm-s
              • Davidus
                • Dec 2010
                • 281
                By the way, you cant use 64bit MYSQL with Zabbix as I know so try 32...
                • dave_t
                  • Apr 2007
                  • 28
                  Thanks davidus, I was going round in circles for a while.
                  I also just spotted your comment on the 64bit version, so have just re-installed 32bit ver.
                  Unfortunately, the retrograde to AIX 5.3 is now giving me the same problem as you originally reported (and the same one as I had on my AIX 6.1 partition):
                  i.e.
                  root@zabbix-master:/home/zabbix_server/zabbix-1.8.3 > make
                  Making all in src
                  Making all in libs
                  Making all in zbxcrypto
                  gcc -DHAVE_CONFIG_H -I. -I../../../include -g -O2 -I'/usr/include/mysql' -MT md5.o -MD -MP -MF .deps/md5.Tpo -c -o md5.o md5.c
                  from md5.c:54:
                  I don't necessarily believe the proglem is just with the brackets.
                  I'll keep chipping away and come back to you if I manage to resolve it.
                  ....as they say: "so near, but yet so far"
                  Dave
                  • Davidus
                    • Dec 2010
                    • 281
                    Dave
                    talking about your issue
                    to
                    this worked out, and I was happy for limited time
                    and this change took me to the next issue
                    now I`m trying to solve this problem, which seems is in db.c file`s code or somethin` like that...
                    If I`ll found solution will inform you asap
                    • dave_t
                      • Apr 2007
                      • 28
                      don't know if this is of any relevance, but I've been back through my config.log and noticed the following:
                      configure:10094: checking for mysql_config
                      configure:10112: found /usr/bin/mysql_config
                      configure:10125: result: /usr/bin/mysql_config
                      configure:10240: checking for main in -lmysqlclient
                      configure:10269: gcc -o conftest -g -O2 -I'/usr/include/mysql' -L/usr/local/mysql/lib -lmysqlclient -L'/usr/lib/mysql' conftest.c -lmysqlclient -lperfstat
                      >&5
                      configure:10275: $? = 0
                      configure:10293: result: yes
                      configure:10496: checking for function PQserverVersion()
                      configure:10524: gcc -o conftest -g -O2 -L/usr/local/mysql/lib -lmysqlclient conftest.c -lperfstat >&5
                      conftest.c:97:22: error: libpq-fe.h: No such file or directory
                      conftest.c: In function 'main':
                      conftest.c:103: error: 'PGconn' undeclared (first use in this function)
                      conftest.c:103: error: (Each undeclared identifier is reported only once
                      conftest.c:103: error: for each function it appears in.)
                      conftest.c:103: error: 'conn' undeclared (first use in this function)
                      conftest.c:103: error: 'NULL' undeclared (first use in this function)
                      configure:10530: $? = 1
                      configure: failed program was:
                      | /* confdefs.h. */
                      • Davidus
                        • Dec 2010
                        • 281
                        what gave you such error? ./configure?
                        I never this kind of error before... hmmm
                        • dave_t
                          • Apr 2007
                          • 28
                          yes, just the following:
                          root@zabbix-master:/home/zabbix_server/zabbix-1.8.3 > ./configure --enable-server --with-mysql
                          frustrating, but I'm going to have to leave this for today. maybe a pair of fresh eyes in the morning will help (or maybe not)
                          • Davidus
                            • Dec 2010
                            • 281
                            which gcc are you using by the way
                            gcc -v
                            mine is 4.2.4 I believe
                            and which mysql-client, mysql-devel are they rpm-s?
                            • Davidus
                              • Dec 2010
                              • 281
                              #15
                              I`m out of office as well, however, cant stop thinking about this issue...
                              in my personal opinion its all about source code! too bad nobody is helping us... real word
