Bug in Agent 1.8.2 with disk size (vfs.fs.size)
  • prote
    • Dec 2008
    • 16
    Some days ago I had problems with Custom multiplier and Network Traffic but I doesn't waste time to test and I removed the Custom multiplier. Today I observed that some of my servers have PB (PetaByte-Disks) or Disks with some hundreds of TB - but I'm sure they don't have
    Exactly the trigger on
    vfs.fs.size[/,total]
    uses in my template a Custom multiplier of 1024 and Units "B". Some dozens of Linux-Servers with Agent-versions 1.4.6 or 1.6.1 show the right size but every Server with an 1.8.2-Agent shows 1024 (or 1000?) times to much total disk space. I don't know if the problem is the multiplier itself or the response from the client.
    An example:
    zabbix_get -s1.2.3.4 -p10050 -k"vfs.fs.size[/,total]"
    1486071214080
    That are with Custom Multiplier 1.35 PB but the right size of this disc is 1.4 TB. Can anyone put this on bugtracker please?
    Edit: server is Zabbix 1.8.2 on Debian Squeeze
  • richlv
    • Oct 2005
    • 3112
    zabbix agent starting with version 1.8 returns bytes on all platforms - before that it was slightly inconsistent and returned bytes on some and kb on others
    • prote
      • Dec 2008
      • 16
      Ihh .. ohh ... mhhh ... ok ^^ Thx That's a little bit ugly if you have many different systems. I have most servers on Debian stable but some are with testing/unstable-Packages or with Ubuntu and on a Debian-system I hate it to use packages which are not in the official mirrors. The Winmachines are not a problem for me, they are all with v1.8.2.
      Is there a workaround to adjust the values on serverside? It has to DIV/MUL the response in dependence of the value of "zabbix_agentd -V"
      Edit: ok, I decided to install the 1.8.2 on all monitored servers ... puh ... Here are the lines you need to copy the files from an 1.8.2-debian-host to an other:
      # cd /var/cache/apt/archives/
      # rsync -ahv 1.2.3.4:/var/cache/apt/archives/zabbix-agent_1%3a1.8.2-1squeeze1_amd64.deb .
      # rsync -ahv 1.2.3.4:/var/cache/apt/archives/libopenipmi0_2.0.16-1_amd64.deb .
      # dpkg -i zabbix-agent_1%3a1.8.2-1squeeze1_amd64.deb libopenipmi0_2.0.16-1_amd64.deb
      Not nice but it works. I should only remember about this if there are new versions avaliable cause apt holds them now on 1.8.2
      • richlv
        • Oct 2005
        • 3112
        well, you could use two different templates depending on agent version and use multiplier only for older agent. not that nice as well...
        • qix
          • Oct 2006
          • 423
          Perhaps setup a small (internal) apt system of your own with your current version for the agent? It's basically just a little website that you add to your sources.list files on your client servers. You might want to build your own packages with a slightly different name to prevent conflicts.
          You could then release a new agent when you are ready for rollout to your servers.
          Now to find a way to port APT to windows
          With kind regards,
          Raymond
          • boy01
            • Dec 2007
            • 24
            Don't want to do that, so here's the patch for linux hosts (zabbix v1.8.4):
            $ diff -uN src/libs/zbxsysinfo/linux/diskspace.c.ORIG src/libs/zbxsysinfo/linux/diskspace.c
            --- src/libs/zbxsysinfo/linux/diskspace.c.ORIG  2011-01-04 15:57:50.000000000 +0200
            +++ src/libs/zbxsysinfo/linux/diskspace.c       2011-01-28 10:49:46.000000000 +0200
            @@ -38,11 +38,11 @@
                            return SYSINFO_RET_FAIL;
                    if (total)
            -               *total = (zbx_uint64_t)s.f_blocks * s.ZBX_BSIZE;
            +               *total = (zbx_uint64_t)(s.f_blocks * (s.ZBX_BSIZE/1024.0));
                    if (free)
            -               *free = (zbx_uint64_t)s.f_bavail * s.ZBX_BSIZE;
            +               *free = (zbx_uint64_t)(s.f_bavail * (s.ZBX_BSIZE/1024.0));
                    if (used)
            -               *used = (zbx_uint64_t)(s.f_blocks - s.f_bfree) * s.ZBX_BSIZE;
            +               *used = (zbx_uint64_t)((s.f_blocks - s.f_bfree) * (s.ZBX_BSIZE/1024.0));
                    if (pfree)
                            if (0 != s.f_blocks - s.f_bfree + s.f_bavail)
