what is a gui name?
  • jmw
    • Nov 2010
    • 14
    what is a gui name?
    i'm facing the problem:
    Sending list of active checks to [192.168.0.214] failed: host [zabbix.mydomain.tld] not found
    in the link:
    people write, that die hostname and GUI name must be identical.
    what's a gui name?
    well the hostname of the server all zabbix agents use is:
    Hostname=zabbix.mydomain.lu
    ( configured in /etc/zabbix/zabbix_agentd.conf )
    thanks a lot
  • nelsonab
    • Sep 2006
    • 1233
    The hostname in the zabbix_agentd.conf file and the hostname field in the configuration gui for the host must be the same.
    If that is the case then look at agent-> server connections. Can the agent connect to the server on port 10051? Are there any firewalls in the way?
    RHCE, author of zbxapi
    • simonuk1
      • Mar 2009
      • 66
      Just to reiterate Nelson, make sure the name is the same , both in characters and also case.
      Cheers
      Si
