building under solaris 10
  • korys
    • Oct 2008
    Hi and happy new year everyone,
    i`m trying build 1.8.3. under solaris 10.
    CFLAGS="-I./include -I/usr/sfw/include -I/opt/csw/include -I/opt/csw/include/mysql" ./configure --enable-server --with-mysql=/opt/csw/mysql5/lib/mysql/libmysqlclient.so
    Succesfully done
    And while building get this error:
    Undefined first referenced
    symbol in file
    mysql_next_result ../../src/libs/zbxdb/libzbxdb.a(db.o)
    ld: fatal: Symbol referencing errors. No output written to zabbix_server
    collect2: ld returned 1 exit status
    *** Error code 1
    make: Fatal error: Command failed for target `zabbix_server'
    Current working directory /root/install/zabbix-1.8.3/src/zabbix_server
    *** Error code 1
    The following command caused the error:
    failcom='exit 1'; \
    for f in x $MAKEFLAGS; do \
    case $f in \
    *=* | --[!k]*);; \
    *k*) failcom='fail=yes';; \
    esac; \
    done; \
    dot_seen=no; \
    target=`echo install-recursive | sed s/-recursive//`; \
    list='alerter dbsyncer dbconfig discoverer housekeeper httppoller nodewatcher pinger poller timer trapper utils watchdog escalator proxypoller'; for subdir in $list; do \
    echo "Making $target in $subdir"; \
    if test "$subdir" = "."; then \
    dot_seen=yes; \
    local_target="$target-am"; \
    else \
    local_target="$target"; \
    fi; \
    (cd $subdir && make $local_target) \
    || eval $failcom; \
    done; \
    if test "$dot_seen" = "no"; then \
    make "$target-am" || exit 1; \
    fi; test -z "$fail"
    make: Fatal error: Command failed for target `install-recursive'
    *** Error code 1
    failcom='exit 1'; \
    case $f in \
    *=* | --[!k]*);; \
    esac; \
    done; \
    dot_seen=no; \
    list='libs zabbix_server '; for subdir in $list; do \
    dot_seen=yes; \
    else \
    fi; \
    || eval $failcom; \
    done; \
    fi; test -z "$fail"
    *** Error code 1
    failcom='exit 1'; \
    case $f in \
    *=* | --[!k]*);; \
    esac; \
    done; \
    dot_seen=no; \
    list='src create man misc upgrades'; for subdir in $list; do \
    dot_seen=yes; \
    else \
    fi; \
    || eval $failcom; \
    done; \
    fi; test -z "$fail"
    LPby on this forum had very similiar problem, he sold it by CFLAGS and copying header files from /opt/csw to zabbix include directory, but this is not working on my box. Has someone any ideas? Thx
