Map Design
  • nilesh
    • Nov 2010
    Map Design
    I am configuring map for router links, i want to set a good image at background.
    please tell me which image files are supported in zabbix. From Where i can get such images and icons for routers, servers, switches, voip and iphones.
  • AlfredIT
    • Jan 2011
    You can use JPG for shure, never tested with oter stuff. The import module is un Administration menu / General then cliick on he right menu to search "Images"
    • nilesh
      • Nov 2010
      Map Design
      Thank you for ur support.
      One more thing, i draw the map for router links, i displayed the B/W utilization on the map using macro, now the problem is it taking lot of space & overlapping on other label. is there any way to make it short and near to host and not at longer distance. Also it is coming with square around it, i dont want like that. i want it should be simply a no. without any design & near to its relevent host. Please help.
      • rodrigo.root.rj
        • Jun 2010
        • 26
        com o que vocĂȘ quer
        i dont undestand your questions, please print something like with what you want.
