Slow process on mass host creation/import
  • xsbr
    • Oct 2009
    • 25
    Version: 1.8.4 stable using MySQL
    I'm syncing my CMDB system with Zabbix using API mode. On first charge, I need create 10000 hosts and this process was taking too long.
    Looking into MySQL's process list, I got this query:
    SELECT max(ht.hostid) as hostid, ht.templateid
    FROM(
    	SELECT count(htt.templateid) as ccc, htt.hostid
    	FROM hosts_templates htt
    	WHERE htt.hostid NOT IN (
    		SELECT httt.templateid FROM hosts_templates httt
    	GROUP BY htt.hostid
    ) ggg, hosts_templates ht
    WHERE ggg.ccc>1 AND ht.hostid=ggg.hostid
    GROUP BY ht.templateid
    This query is present on file api/classes/class.ctemplate.php in line 1651
    Running this query manually took 30 seconds (10000 hosts linked). EXPLAIN method show me that some code was running without indexes.
    The solution was create individual indexes for "hostid" and "templateid", because the original schema only offers a unique key with both columns.
    ALTER TABLE `hosts_templates` ADD INDEX ( `hostid` )
    ALTER TABLE `hosts_templates` ADD INDEX ( `templateid` )
    Now I can insert 100 hosts per second.
    I think this issue affects all host creation methods: FrontEnd, API and XML Import
  • xsbr
    • Oct 2009
    • 25
    Bug reported
    • jean
      • Apr 2006
      • 85
      I have applied your "solution" and now the import operation works as never !!!
      Thank you so much !
